Suspension question
Old Apr 6, 2012 | 05:59 PM
scottermis's Avatar
scottermis
Default Suspension question
I put new Bilsteins on my 94 after i bought it with shocks that were worn out. Assuming the new Bilsteins would take out the "boat effect" at high speeds 70+ i was a bit dissappointed. What do i need to do to make the suspension a bit stiffer do i need to put a suspension kit on it or can i do something cheaper?
Old Apr 6, 2012 | 06:39 PM
2fas2c's Avatar
2fas2c
what are the cond. of your ball joints, tie rods rear center link and bushings? replacing the all the susp. bushings with urethane ones is a good cheap upgrade and reduces body roll quite a bit. If your ball joints + tie rods are in disrepair I would start there though, no sense in upgrading if the basics are no good. While your in there replace the end links.
Old Apr 6, 2012 | 07:13 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Explain "boat effect"?
If that means the front end feels light like its comming up - check your front air dam and make sure ALL the pieces are there and in good shape.
Mine would start to lift at 80+ on the straight on a road course cause one piece of the air dam was damaged.
Old Apr 6, 2012 | 07:31 PM
scottermis's Avatar
scottermis
Ip ut a set of SU-814 and SU-815 Bilsteins on the car a month ago and it has 33k miles on it. Being a 94 model it has really low mileage buti replaced the old Bilsteins as they were the original shocks that came on it. I think maybe i expected a little tighter suspension on the car as i have never owned a vette before but the air dam and most everything on the car are in pretty perfect shape. The front of the car just feels like it floats some on an aggressive start or driving on the interstate as around 70-130. Maybe it is just me and its an older car and is supposed to be that way?
Old Apr 6, 2012 | 08:47 PM
rodj's Avatar
rodj
Originally Posted by scottermis
I think maybe i expected a little tighter suspension . The front of the car just feels like it floats some on an aggressive start or driving on the interstate as around 70-130. Maybe it is just me and its an older car and is supposed to be that way?
The later C4's like yours are way softer than the earlier cars because the golf club on Sunday set first owners
wanted a luxury performance car ; not a performance car , so GM soften up the suspension to accommodate them
Fitting the springs / swaybars from a earlier (>'88 car) will regain some control ( stiffer ) but with a obvious loss
of ride comfort if you are looking for Caddy quality at the same time
Old Apr 6, 2012 | 08:48 PM
93Rubie's Avatar
93Rubie
What suspension do you have base, FX3?
The 94's have some soft springs and with base suspension soft shocks. My buddies 94 feels way softer than my 93 FX3 does even in touring mode.
Old Apr 13, 2012 | 10:17 AM
scottermis's Avatar
scottermis
Would coilovers be a good option and if so can anyone recommend a good brand?
Old Apr 13, 2012 | 11:35 PM
Analog Kid's Avatar
Analog Kid
Check the diameter of your front sway bar. Sometime in the last few years of the C4 production run, they started putting 24mm front bars on the base/FE1 models and you get the poor high speed feel you are describing.
You can go up to 26mm, 28 or 32 using factory bars from different models (junk yard). There are companies that sell them as well.
I picked up a used 26mm bar and bought some poly sway bar bushings and it made a huge difference.
Old Apr 14, 2012 | 08:54 AM
Churchkey's Avatar
Churchkey
I would keep the soft springs.
The front running short track pavement oval cars use soft springs, good shocks & large sway bars.
Suggest checking the front wheel alignment to insure there is enough caster. Light caster settings will give a loose front end feel at speed. On vehicles that have tires with a large foot print like our Vettes the loose feed back feel is multiplied. Large foot print tires are also prone to rutting caused by uneven road surfaces created by large trucks. Moving left to the hammer lane will eliminate this type of road feel. I suspect GM addressed the rutting problem in the later C4's by reducing front rim width by one inch to 8.5.
With correct caster settings the vehicle should feel planted at speed provided camber & toe settings are in spec.
Tire brand and age also enter into the equation.
GL
Old Apr 14, 2012 | 02:21 PM
scottermis's Avatar
scottermis
GL
I just put a new set of NITTO NT555's on it all the way around but it was doing it before the new shoes. After measuring the front sway bar it is indeed a 24mm so i ordered a 29mm from addco with new poly bushings. I bet that fixes it ! Thanks you guys for all your input!!!!
To Suspension question
