New Vette owner with big problems.
Old Apr 7, 2012 | 02:19 AM
Cut-n-Shoot's Avatar
Cut-n-Shoot
4th Gear
Default New Vette owner with big problems.
Ran across a deal I couldn't pass up, but now I think I should have. It's a '90 Vette that had been sitting for a while. Someone has added a cam & headers, and possibly other stuff I can't see. I have replaced the fuel pump, injectors, tps, o2 sensor, and a couple other sensors. The problem is, it runs extremely rich. It runs great going down the road at higher rpm, but smokes at idle (fuel not oil) & keeps fouling the spark plugs..
I really don't know much about these engines & I'm not sure what to do. I'm guessing the cam has got the computer going crazy?? Any advice would be great!
Old Apr 7, 2012 | 03:19 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If it has a lumpy cam you should notice it at idle and low rpm.
I suggest you get the ECM scanned to see what's up; it will show fuel correction tables as well as all sensor values.
Remember that year is speed density; i.e. uses manifold pressure and air time to determing air flow. Either of those sensors could cause false enrichment, but a scan tool should show the real story.
Old Apr 7, 2012 | 08:37 AM
blkzr1's Avatar
blkzr1
Default help
hi, if you can, contact corey henderson at henderson performance technologies and set up a dyno tune. he is in new braunfels tx and he is very good at tuning. i have been there several times and they treat me like a king, in other words, they have great coustomer service. he will share all that he knows about vettes if you ask. you will not be disappointed. see ya
Old Apr 7, 2012 | 09:10 AM
desertmike1's Avatar
desertmike1
This could be a leaking fuel pressure regulator diaghram, remove the vacuum hose attached to FPR and look for signs of fuel. Do you have a FSM?
Old Apr 7, 2012 | 10:22 AM
cv67's Avatar
cv67
St. Jude Donor '05
Corey is an expert he can sort it out real quick.
If it hasnt had one already it could be in need of a chip retune.
Coreys your man and knows C4s real well.
Old Apr 7, 2012 | 11:24 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
What brand O2 sensor did you put in?
Several folks have reported problems with Bosch sensors.
NTK or Denso are good replacements.
I had that problem on my 92 even with a new chip for the mods.
The o2 sensors just weren't responsive and NO codes
Old Apr 7, 2012 | 11:45 AM
Road Agent's Avatar
Road Agent
I installed Bosch and had similar problems! I ended up ordering AC Delco from Napa. Big differance!
Old Apr 7, 2012 | 01:38 PM
Cut-n-Shoot
4th Gear
Thanks for all the replies. I'm pretty sure it was a Bosch O2 sensor I put in. I'll start with changing that & go from there. I also just ordered a FSM to help me learn about the car. I would love to take it & have it dyno tuned, but that's just not in the budget right now.
Old Apr 7, 2012 | 03:36 PM
383vett's Avatar
383vett
The op appears to be in New York. His enging will be toast driving that far with fuel washing down the cylinder walls.
Old Apr 7, 2012 | 03:47 PM
Cut-n-Shoot
4th Gear
Nah, I'm near Houston, it's about 3 hour trip from here. Just wish I had the $$.
Old Apr 9, 2012 | 04:41 PM
Cut-n-Shoot
4th Gear
Default Update..
Just though some of y'all might want to know... I was talking with the guy I got the car from & he told me he had a new ECM that he never installed. I installed it & the cars runs great now.
Old Apr 9, 2012 | 04:52 PM
desertmike1
Good to hear, it's always nice when we post our fix's this may help somebody else some day.
Old Apr 9, 2012 | 07:00 PM
ghlkal's Avatar
ghlkal
2018 C4 of Year Finalist
I agree.
Also, you really should take your Vette to Corey @ Henderson Performance. It's well worth it for anybody within a day's drive.
To New Vette owner with big problems.
