Do fuel injectors "click"?
Old May 18, 2002 | 11:38 PM
FlyboyZR1's Avatar
FlyboyZR1
Default Do fuel injectors "click"?
I notice this constant "clickclickcliclick or ticktickticktick" noise under acceleration or at idle with the hood open. Sounds like it comes from the top of the engine, maybe the injectors. The previous owner said it was the exhaust manifold gasket, but I dont buy that. Do injectors click, and why?
Old May 18, 2002 | 11:44 PM
Rynda's Avatar
Rynda
Default Re: Do fuel injectors "click"? (FlyboyZR1)
Yes, they do tick. Sometimes you would almost think that you need to adjust the lifters. Mine has been noticable since it was new.
Old May 19, 2002 | 12:26 AM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
Depends on the how the click sounds. If its just idle, its probably injectors. Exhaust leaks are still noticeable when the motor revs. Same for lifters. Get an auto mechanic stethescope if your in doubt. They are pretty cheap.
Old May 19, 2002 | 01:24 AM
jfb's Avatar
jfb
Do injectors click? Are frogs waterproof? Injectors have a needle valve closed by a spring in them. They also have a coil which is supplied a current pulse by the ECM which opens them to spray gasoline into the intake manifold. The length of the pulse is controlled by the throttle position sensor, more throttle , longer pulse, more fuel , more hp. On your 86 one whole bank (each side) of the injectors are pulsed at the same time which makes for one heck of a CLICK. In later years, GM finally sequenced the injectors, that is , the injector for the next intake stroke only was pulsed. Still clicked, but not as loud as 4 of them opening and closing at the same time.
[Modified by jfb, 11:25 PM 5/18/2002]
Old May 19, 2002 | 01:30 AM
tarheelracer's Avatar
tarheelracer
Default Re: Do fuel injectors "click"? (jfb)
Yep, gotta love the injector click. Whenever somebody looks at my engine with my hood open they are like, are your valves out of adjustment, and I'm like, nope, that's the injectors.
Old May 19, 2002 | 07:01 PM
LPDesRoche's Avatar
LPDesRoche
Yep....very loudly at that....gotta love the batch fire setups...
Old May 19, 2002 | 07:54 PM
GlockLT4's Avatar
GlockLT4
Default Re: Do fuel injectors "click"? (LPDesRoche)
don't forget sequential for us 94+ guys :D
Old May 19, 2002 | 08:57 PM
Juliet's Avatar
Juliet
Yes they do. Quite loudly infact. :)
Old May 19, 2002 | 09:45 PM
LT5's Avatar
LT5
Default Re: Do fuel injectors "click"? (Juliet)
:yesnod:
To Do fuel injectors "click"?
