High Voltage
Old Apr 9, 2012 | 08:19 PM
joe wilson's Avatar
joe wilson
Default High Voltage
My voltmeter light came on recently and the gauge shows 15.5 to 17 volts. It's a stock 85 Corvette. I thought when the alternator went bad the voltage went down. Last year while I was driving it the voltage was below what it should be, just under 13 volts. I let it sit over the winter, started it up this Spring and it's been high ever since. Any suggestions?
Old Apr 10, 2012 | 08:56 AM
Steve59's Avatar
Steve59
Had the same problem in my 87, Voltage reg went. Needed a new Alternator and battery. Seemed as if it boiled the battery.
Old Apr 10, 2012 | 09:27 AM
c4cruiser's Avatar
c4cruiser
Sounds like the internal regulator (inside the alternator) has died.
But you should check the alternator output with a digital voltmeter. With the engine running , check the voltage at the large stud on the alternator and also across the battery terminals. You should see something between 13.7v to 14.2 volts depending on the state of charge in the battery.
With the engine off, a fully charged battery should show about 12.8v.
If the alterntor is bad, get a good quality remanufactured unit. Some of the chain auto patrs stores versions are rebuilds and not remanufactured. I would recommend an AC Delco remanufactured alternator.
Old Apr 10, 2012 | 10:02 AM
joe wilson's Avatar
joe wilson
I did check it with a voltmeter. Just like you said, from the alternator terminal to ground and across the battery. It measured the same as the meter on the dash, hovering just below or at 17 volts. I spotted some chrome alternators on ebay, 110 amps, brand new for cheaper than the remans. Do you think it would be a better deal?
Forgot to mention the new one had a one year guarantee.
Old Apr 10, 2012 | 10:32 AM
Muffin's Avatar
Muffin
Rockauto sells several remans in the $70-$90 range. I am not understanding how someone could sell a new chrome unit for less unless it came packed in rice. Your smartest move,IMHO, is to find a local auto electrical shop and have yours rebuilt. Cost is usually less than a store bought rebuild. If you want bling and are willing to take the risk, go for the chrome.
If you are interested in a learning experience rebuild it yourself. Kits with super simple directions are available at most parts stores.
Old Apr 10, 2012 | 10:37 AM
c4cruiser's Avatar
c4cruiser
While some people say that C4's are hard on alternators (attributed to high underhood temps), the AC Delco reman unit on my 87 has lasted 10 years.
Don't buy a cheap alternator! If you drive the car regularly, a cheap unit will probably not last more than a few years. I'll bet the fleabay uinit is most likely an offshore rebuild with a chrome-plated case; you will get what you pay for.... Most any reman alternator bought at parts stores like AutoZone or O'Reilly's will have a 1-year warranty.
Rockauto.com shows two AC Delco alternators for an '85; one is 108 amps output (p/n 3342311), the other is 120 amps (p/n 3342180. Either one is under $100.
Old Apr 10, 2012 | 11:31 PM
joe wilson's Avatar
joe wilson
Well, to tell you the truth, I hardly ever drive the Vette anymore. I mainly just start it up once in a while and drive it for a few miles to keep the oil stirred up. When something's wrong with it I still want it fixed so maybe I can sell it some time. I've been driving my gas mileage car lately since we've had $4 gas, Vette sits in garage.
I bought a new mini starter for it a couple of years ago, I wonder if it was an oriental product also? It seems to work better than the original...
To High Voltage
