93 corvette fuel pump
Old Apr 11, 2012 | 10:00 PM
maverick1453's Avatar
maverick1453
Default 93 corvette fuel pump
I have a basic 93 corvette not zr1
IM replacing the furl pump. IM reading the chilton manual and it says u can just go through fuel filter cap area and seems somewhat simle.
but some mechanics I talk to say to drop the fuel tank. ?
anyone have any input on this thanks u
Old Apr 11, 2012 | 10:11 PM
94z07fx3's Avatar
94z07fx3
Don't drop the tank!
Don't remove the fuel fill door!
Do remove the cap. The Pan that sits around the filler neck is rubber-like and will slide off the filler neck if you poke one corner down and get some fingers under it.
There are a few hoses that will be almost welded onto the metal tubes by now so figure on cutting them off if needed. Do it right and there will be enough slack to reuse them.
Remove the bolts around the filler tube plate and the filler tube and fuel pump will lift off. Replacement gaskets are available at TLD and the other catalogs.
Duct tape the open hole in the top of the tank while you have the pump out.
Replace the sock!
Old Apr 11, 2012 | 10:12 PM
JackDidley's Avatar
JackDidley
Dont drop the tank. Go in through the top. Should not take over an hour. No sweat involved. Very easy.
Old Apr 11, 2012 | 10:13 PM
VetteMed's Avatar
VetteMed
when I swap a fuel pump in a C4, I do remove the filler door assembly. It's 4 screws, and removing it gives easier access to the multiple bolts and hoses you need to remove.
Old Apr 12, 2012 | 12:25 AM
rodj's Avatar
rodj
http://forums.corvetteforum.com/c4-t...s-of-pics.html
http://www.joby.se/corvette/mods/2001-0X07_fuelpump/
Old Apr 12, 2012 | 03:02 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I use a pair of chanel-locks to break loose the hoses to avoid cutting them off.
Old Apr 12, 2012 | 06:11 AM
kenmohr's Avatar
kenmohr
Me too. Just change mine a week ago. Not a hard job. My wife caught me going over all I had done. sHE ASKED "SOMETHING WRONG". i ANSWERED NO IT JUST SEEMED TOO SIMPLE. LOL Go for it.
Old Apr 12, 2012 | 09:07 AM
JackDidley's Avatar
JackDidley
Me too. It makes it easy to clean around the whole area. Dont want a lot of crap falling in the tank.
Old Apr 12, 2012 | 09:58 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Lots and Lots and Lots easier.
Old Apr 12, 2012 | 10:58 AM
96GS#007's Avatar
96GS#007
Drop the tank?! Don't take the car to those guys.
To 93 corvette fuel pump
