Code '28' is quad drivers that control fan and a/c relays. I don't see what affect either would have on ignition spark.
I tried the noid light test again, no flashing light while cranking....
Sara Lou
OK. I didn't know what the quads controlled. I probably should have read through the whole thread again before posting.
Looking through my '94 FSM and a couple of other 90's era GM FSMs, they all indicate that the ECM will not pulse the injectors unless you have good feedback from the ignition control module and/or reference pulses from the Opti.
What part of Birmingham are you in? It doesn't look like downtown. I am in Huntsville (and it is awful bleeping cold for MAY~!)
The ICM was replaced along with the coil, so i'm discounting those.
I'm in Pell City which is east of birmingham down I20.
The no pulse reference at the injectors is verifying what I suspected all along, either ECM or Opti, its just narrowing it down to which one....
I have replaced Opti. Coil and ICM, now looking at Injectors which are showing Resistance Variations greater than 1 Ohm which can cause starting problems...
I bought Chopperclays 93 Ruby, he gave up on fixing it, I replaced the PCM and it runs fine now.
