Car stumbles when driving
Old May 19, 2002 | 07:08 PM
your drinking buddy's Avatar
your drinking buddy
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Default Car stumbles when driving
This just started up about three days ago. If I accelerate or just cruise at any speed, the car stumbles about every 10 seconds. If I punch it, she feels like a dog, then speeds up, then slows again. When I slow to a stop, the RPMs fall and the engine may die on me, it has a few times at stoplights. Before this happened, the idle was around 750 when heated up, but sometimes it falls to 500 for a second and barely goes back up. :confused:
Old May 19, 2002 | 07:22 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Car stumbles when driving (vettes rule)
What year & engine??
Old May 19, 2002 | 07:26 PM
your drinking buddy
Cruise-In V Veteran
Default Re: Car stumbles when driving (65Z01)
Sorry, 91 L98 auto
Old May 19, 2002 | 07:41 PM
65Z01's Avatar
65Z01
That's good, at least you don't have to worry about an "opti".
The idle issue sounds like the IAC needs attention.
The stumble could be any of several things. If you had a MAF I'd suspect it but don't now the failure symptoms of a MAP sensor.
On the stumble does it miss or just die out?
Old May 19, 2002 | 07:47 PM
your drinking buddy
Cruise-In V Veteran
Most of the time it just misses, but every once in a while when I stop, it dies.
What should I do with the IAC and how?
Old May 19, 2002 | 07:56 PM
GlockLT4's Avatar
GlockLT4
Pull it out and clean the pentel off. Probably has some carbon deposits on it that are keeping it from opening/closing the proper amounts.
Old May 20, 2002 | 10:16 AM
chucks88's Avatar
chucks88
Default Re: Car stumbles when driving (Glock'94)
I was getting a rough idle, sputtering, stalling etc. It turned out to be my MAF sensor. I found this out by..........
When the car is idling rough, tap on the bottom (square box looking thingy) with a screw driver to see if the idle changes with the taps. If it does you may have found the culprit.
I was getting no codes while my MAF sensor was going south on me.
Old May 20, 2002 | 10:28 AM
Mr. Sharky's Avatar
Mr. Sharky
Default Re: Car stumbles when driving (chucks88)
What does IAC and MAF stand for? :confused:
Old May 20, 2002 | 10:33 AM
onedef92's Avatar
onedef92
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default Re: Car stumbles when driving (Mr. Sharky)
Idle Air Control (IAC) valve and Mass Air Flow sensor (MAF) respectively.
Old May 20, 2002 | 10:59 AM
your drinking buddy
Cruise-In V Veteran
I have speed density and not MAF
Old May 20, 2002 | 11:15 AM
wzd922's Avatar
wzd922
does a 88 have a IAC and if so where is it located and how tough is it to get to? Also where is the MAF located and do I replace it or clean it? My car was tuned and now it surges when driven, but when I step on it, it stops surging and just goes fast. thanks
Old May 20, 2002 | 08:12 PM
chucks88's Avatar
chucks88
Default Re: Car stumbles when driving (wzd922)
I think you should start by at least getting a Haynes manual. My '88 came with a MAF sensor. The MAF sensor is the only apparatus located between your air filter and and throttle body that has an electrical connection to it.
You better not ask whats an air filter and what's a throttlebody :rolleyes:
Go get a manual.
Old May 20, 2002 | 08:15 PM
your drinking buddy
Cruise-In V Veteran
I have a Haynes manual, and im pretty sure 91 vettes are speed density and not mas air flow
Old May 20, 2002 | 11:36 PM
94-LT1's Avatar
94-LT1
always check easy stuff first. Plugs, wires, cap, rotor. Also check for VACUUM LEAKS.
Old May 20, 2002 | 11:55 PM
8LivesLeft's Avatar
8LivesLeft
Default Re: Car stumbles when driving (94-LT1)
The 90-91's are speed density not MAF, sounds like it could be fuel related, do you have any way to check fuel pressure??
[Modified by 8LivesLeft, 10:56 PM 5/20/2002]
Old May 21, 2002 | 12:16 AM
chucks88's Avatar
chucks88
Sorry, my bad :rolleyes:
Old May 21, 2002 | 12:41 AM
gbr's Avatar
gbr
:yesnod: Absolutely...trust me on this one. I have spent over $1600 dollars in the last 3 months trying to find the cure to a rough idle problem. In the end...what fixed it. Cap, Rotor, and Ignition Module...$100...start with the free/easy stuff first.
To Car stumbles when driving
Old May 21, 2002 | 09:00 AM
onedef92's Avatar
onedef92
Default Re: Car stumbles when driving (gbr)
True dat gbr. When making any sort of diagnoses think AZZ: Always Assume the Simple! :D
[Modified by onedef92, 8:00 AM 5/21/2002]
Old May 21, 2002 | 11:59 AM
ParadiseSD's Avatar
ParadiseSD
Check to make sure that one of your plug wires isn't melted. I found one of mine resting on the exhaust manifold.... burnt right thru.
Old May 21, 2002 | 12:07 PM
rats87's Avatar
rats87
I may just be a newbie, but is it a good idea to change your cap and rotor at a certain milage?
