C4 Master Cylinder Size?
Old Apr 16, 2012 | 09:15 AM
bspvette's Avatar
bspvette
Default C4 Master Cylinder Size?
Hey Gang,
I removed the brake booster from my '85. Would like to bump up to a slightly bigger master cylinder to get a little less pedal effort, but don't want to disassemble the stock unit to measure the bore.
Anybody happen to know he bore diameter on the factory units?
Thanks,
BeerMan
Old Apr 16, 2012 | 09:40 AM
braeburn22's Avatar
braeburn22
Hi
The Master cylinder is 7/8"
Old Apr 17, 2012 | 10:40 AM
bspvette's Avatar
bspvette
Thanks for the quick help.
BeerMan
Old Apr 17, 2012 | 10:50 AM
Churchkey's Avatar
Churchkey
Increasing the MC bore diameter decreases the hydraulic ratio. Brake pedal travel will be reduced however additional force on the pedal will be required to stop the vehicle in a comparible distance.
For less pedal effort the MC bore size will need to be reduced which will increase the hydraulic ratio at the expense of longer pedal travel.
Suggest an 84 MC with bore size .8125 (13/16).
Old Apr 17, 2012 | 10:59 AM
bspvette's Avatar
bspvette
Thanks Churchkey. That makes sense. I guess I've been out of school too long, & didn't think it through properly.
I think a little longer pedal travel might be good anyway, cause it would be a little easier to modulate the brakes.
BeerMan
To C4 Master Cylinder Size?
