Ignition Timing not making sense
Old Apr 18, 2012 | 05:08 PM
1986 4+3 CORVETTE's Avatar
1986 4+3 CORVETTE
Default Ignition Timing not making sense
So i followed the procedure to time my 86 l98 and with the EST diconected it was timed at 8* BTDC, but when i shut my car off and plugged the EST back in and disconected the battery and restarted it was sitting at about 16*-18* BTDC. I dont know why its doing that what should I do?
Old Apr 18, 2012 | 07:06 PM
WW7's Avatar
WW7
That's what its suppose to do......Once you plug the EST back in the ecm takes over your timing again.. Thats why you have to disconnect the est before you start , so your timing isn't influenced by the computer.....WW
Old Apr 18, 2012 | 07:53 PM
1986 4+3 CORVETTE
I did unplug the EST first and when all was said and done my timing was way advanced. Is that what is suppose to happen?
Old Apr 18, 2012 | 08:22 PM
383vett's Avatar
383vett
16 to 18 degrees at idle is what you are looking for. Move on to the next project.
Old Apr 18, 2012 | 08:44 PM
John A. Marker's Avatar
John A. Marker
with WW7 and 383vett. You have set the BASE timing. Once you plug the EST back in, the computer takes over and controls the timing. You are fine.
Old Apr 19, 2012 | 12:35 AM
1986 4+3 CORVETTE
So just to make sure with everything hooked up it sits at 8*
Old Apr 20, 2012 | 09:58 AM
HlhnEast's Avatar
HlhnEast
No, with EST disconnected, it is set at a base timing of 8. When you hook everything up, the car will set the timing thru the computer control. At that point, you need to do nothing as long as its in the 16-18 range as stated.
To Ignition Timing not making sense
