hesatation
Old Apr 19, 2012 | 10:48 AM
sarge77's Avatar
sarge77
6th Gear
Default hesatation
i have a slight hesatation on acceleration idle rough at stop sign any ideas on whats up
Old Apr 19, 2012 | 11:36 AM
MeanMachine350's Avatar
MeanMachine350
St. Jude Donor '12
Does this only happen when you accelerate hard? Does your rpm keep on increasing until you let go of the gas then it shifts?
Old Apr 19, 2012 | 02:25 PM
sarge77's Avatar
sarge77
6th Gear
Default hesatation
when i accelarate easy it seems to hesatate more
Old Apr 19, 2012 | 03:01 PM
MeanMachine350
St. Jude Donor '12
Well we need more information about your car. What year is it? L98? and once again, at what RPM does your car shift from first to second gear? Does it only shift when you let go of the gas?
Try to provide a more detailed response.
Old Apr 19, 2012 | 03:40 PM
Larry/car's Avatar
Larry/car
mass air flow sensor
Old Apr 19, 2012 | 03:41 PM
sarge77's Avatar
sarge77
6th Gear
thx i will try that
Old Apr 19, 2012 | 11:05 PM
sarge77's Avatar
sarge77
6th Gear
rt side light goes up but only closes half way whats wrong?
Old Apr 19, 2012 | 11:45 PM
desertmike1's Avatar
desertmike1
You need to stay on subject!
How do the headlights function with the hood open?
Headlight could be striking the coolant pipe at recovery Reservoir.
Old Apr 19, 2012 | 11:49 PM
sarge77's Avatar
sarge77
6th Gear
car sat for two years i have a few things that need fixed. will check coolant pipe thx.
To hesatation
