6spd jumping up, shift knob dancing etc...
Old May 20, 2002 | 07:05 AM
gtsyellow's Avatar
gtsyellow
Default 6spd jumping up, shift **** dancing etc...
where in the world are the mounts on this zf6? my transmission comes up a good 3" at WOT in 1st. nothing LOOKS loose but i have been fooled before. {header collector gasket rattled loose and fell out on a trip to a club when it LOOKED fine} anyway i'm sure it can't be good on anything for my transmission to be jumping up everytime i gas it. where is the most common cause for this? i'm about to start tearing things apart....
Old May 20, 2002 | 07:35 AM
Sharky Guam's Avatar
Sharky Guam
Default Re: 6spd jumping up, shift **** dancing etc... (gtsyellow)
You have a bad mount somewhere. Or maybe you should check your bolts in the C beam. They might be loose also.
:cheers:
cajun86's Avatar
cajun86
You might check for a broken motor mount especially on the drivers side...
Old May 20, 2002 | 11:27 AM
Corvette0096's Avatar
Corvette0096
I told you some thing was wrong... :yesnod:
Old May 20, 2002 | 12:05 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Re: 6spd jumping up, shift **** dancing etc... (Sharky Guam)
:cheers:
that's what was wrong with mine! :yesnod: :yesnod:
Old May 20, 2002 | 12:26 PM
jsaunde2's Avatar
jsaunde2
Default Re: 6spd jumping up, shift **** dancing etc... (BrianCunningham)
90% your problem is loose bolts at the rear of the tranny holding it to the C-beam thing. You have to drop the exhaust to tighten them and it is generally a bitch. I would recommend you tighten the crap out of them. After having dealers do this three times on my car in 3 years, I did myself once three years ago and it hasn't loosened yet.
Jason
Old May 20, 2002 | 01:23 PM
FoolCrzy's Avatar
FoolCrzy
Default Re: 6spd jumping up, shift **** dancing etc... (jsaunde2)
When you tighten them, Make sure to get a wrench on the nut up top. It's tight up there, but can be done. The fronts are 18mm, the rear is 21mm.
Old May 20, 2002 | 04:01 PM
gtsyellow's Avatar
gtsyellow
Default Re: 6spd jumping up, shift **** dancing etc... (FoolCrzy)
i'll tear into it in the next day or so when i replace the halfshaft i tore to pieces. i broke a mid america u joint into 2 pieces awhile back, chewed the heck out of the half shaft & wound up taking a spare ujoint & welding into the halfshaft for a get me by till my new/used halfshaft showed up at the door. i swear a lot of parts break when you drive your corvette like a bizatch :blueangel:
To 6spd jumping up, shift knob dancing etc...
