E85 may be in your future
Old May 20, 2002 | 10:47 AM
grumpyvette's Avatar
grumpyvette
Default E85 may be in your future
-need to pass emissions make 500hp and reduce the dependence on foreign oil supplies-E85 may be in your future------------------------------------------------------------------------------ http://www.kycorn.org/ethanol/e85vehicle.html http://www.afdc.nrel.gov/documents/...4_4feature.html
http://www.iowacorn.org/e85fuel.htm
http://www.alamn.org/outdoor/e85fuel.asp
http://www.altfuels.org/e85.html
http://www.gplcorp.com/ethanol.html
http://journeytoforever.org/ethanol_link.html
http://www.iowacorn.org/ethanfqs.htm
Old May 20, 2002 | 01:31 PM
SloRvette's Avatar
SloRvette
Cruise-In VII Veteran
Default Re: E85 may be in your future (grumpyvette)
They can't get this stuff out quick enough.
Old May 20, 2002 | 01:32 PM
scorp508's Avatar
scorp508
I'm too dumb to read, summary please. :D
Old May 20, 2002 | 01:36 PM
FoolCrzy's Avatar
FoolCrzy
Default Re: (scorp508)
Old May 20, 2002 | 01:40 PM
SloRvette's Avatar
SloRvette
85% ethanol, 15 % gasoline. 100 + octane. Works great with 11:1 + compression ratio engines. Burns very clean. Money spent at the pumps would go to American farmers, not overseas.
Old May 20, 2002 | 01:53 PM
scorp508's Avatar
scorp508
Sounds good!! And it is fully compatible with our current engines?
Old May 20, 2002 | 02:02 PM
FoolCrzy's Avatar
FoolCrzy
Longer-term use of E85 in gasoline-only vehicles may cause damage because of the incompatibility of the alcohol fuel with the parts in gasoline-only engines. Performance and emissions will also be compromised.
Old May 20, 2002 | 02:07 PM
Corvette0096's Avatar
Corvette0096
This would be great.. But I think it would be a while before anything will happen. if it happens..
Old May 20, 2002 | 02:20 PM
Hotwhlz85's Avatar
Hotwhlz85
Default Re: E85 may be in your future (corvette0096)
I've also read that even though the octane ratings are up there, the btu's that ethanol is capable of producing is not the same as 100% gasoline. Meaning that it doesn't produce the same type of explosion and therefore less power. I'm no engineer so please don't ask me to explain this. Just passing along info.
Ron
:cool:
Old May 20, 2002 | 05:19 PM
grumpyvette
Default Re: E85 may be in your future (Hotwhlz85)
well I am an engineer and while you have the correct idea you don,t have all the info, http://www.bgsu.edu/departments/envh/Oxygenates/
http://wwwchem.uwimona.edu.jm:1104/l...s/synfuel.html
http://www.bgsu.edu/departments/envh...tes/sld002.htm
http://www.epa.gov/otaq/rfg.htm
http://www.epa.gov/otaq/rfgvehpf.htm
http://www.energy.ca.gov/education/AFVs/alcohols.html
short version for those of you that refuse to read, alcohol has a much higher octane rateing but a lower btu level that means it will produce more power than gas but it requires quite a bit more fuel volume per mile traveled, or put another way you can have your 500 plus hp and your clean air but your going to get lousy mileage and might have corrosion problems because alcohol is hygroscopic (absorbs moisture from the air)
To E85 may be in your future
