Check engine light once in a while?
Old Apr 22, 2012 | 01:36 PM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Default Check engine light once in a while?
My 85 stock L98 has a true duel exhaust on it. The catalytic converter was removed. (Antique Plates) No emissions neccessary. The air pump is still in place as well as the EGR valve. I can be cruising at about 50 mph for a few miles and the check engine light will come on. Most of the time it's while I'm in overdrive or the cruise control is set. (4+3 transmission) There is NO problem with the overdrive. After about 5 minutes while I'm still cruisng at same speed, the light will then go out on it's own. Why does it go out on it's own? Or if you turn off the ignition and restart it, the light will be off. The code being stored indicates EGR problem. Could the system be trying to tell me that the catalytic convertor (that's not there any more) is not working? The car runs fine with no problems while this light is on. Should I just disconnect the light, or am I causing a future problem with an EGR and no catalytic converter?
Old Apr 22, 2012 | 01:58 PM
SunCr's Avatar
SunCr
Nope - it's telling you that EGR was commanded and it didn't happen. The design relies on a heat sensitive switch grounding when exhaust passes over it. Your ECM didn't see that ground so it sets the Code. When conditions for EGR pass, it could care less, so it ignores the switch signal - unless it remains grounded, but from what you describe, that isn't happening.
Since when did an OEM vehicle with a CAT become exempt from the FED rules?
Old Apr 22, 2012 | 02:06 PM
Old Ben's Avatar
Old Ben
2017 C6 of Year Finalist
What Federal rule? What smog test? Here in Alabama there is NO vehicle inspection at all.
Old Apr 22, 2012 | 02:25 PM
FOURSPEEDVETTE
In Pennsylvania, A car with Antique or Classic Car plates does not require an emissions test. These type plates indicate the car is driven very little and only for certain type functions or activities. Not a daily driver in other words. Being there is no emissions test needed, I like many thousands of others removed the cat and put straight through pipes on it for better performance. Being it is an "antique" and meeting all the age requirements and legal regulations of an "antique" it's the same as driving a vehicle say from the 1960's era.
Old Apr 22, 2012 | 02:46 PM
SunCr's Avatar
SunCr
Emission test or no Emission test, no vehicle is exempt from the Fed Requirement to have a CAT - they even make reporting violations/tampering easy with a link at the epa site, though they prefer to prosecute shops, Dealers, etc. Speaking of Dealers, a Dealer that accepts a tampered vehicle as a Trade-in has a requirement to report it (along with fixing it if they want to resell it). Didn't any of you take Civics in High School? Fed Law does supersede State Law from time to time. None of us are special - or exempt from these requirements and the majority of car owners get it. For the few that don't, I don't think they're causing much harm, but like a neighbor that cheats on his/her taxes while you pay your full dime, it tends to rankle you from time to time.
Old Apr 22, 2012 | 04:39 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Jumper the ALDL pins A&B, turn on ign sw and count the flashes to verify a code "32" has been set.
If so it is indeed an EGR problem.
I have the same symptom with my "new" '88. Rather than diagonse the fault I've ordered a new EGR Temp sw. If that doesn't solve the pesky SES light issue I'll install a 160 deg T-stat as the ECM will NOT call for EGR untill coolant temp is >175deg F.
If any issues with the "no cat" problem, just pick up a used one from a bone year, gut it and install...
Old Apr 22, 2012 | 07:09 PM
C4in mesa's Avatar
C4in mesa
Default God Bless Alabama !
I see nor reason unless you live in a big city why you should have to runa restrictive exhaust system. I live in Mesa AZ Maricopa county and emissions are law. I could register it in another county to avoid this and gain the HP I am being denied. I am having second thoughts due to resale. If I decide to sell the car I will have to spend several hundred dollars just to sell the car. Not sure I want to go through all that. If you dont have the same regulations then run it brother ! How loud is it ? So bad you cant hear music ?
Old Apr 22, 2012 | 09:31 PM
FOURSPEEDVETTE
I would venture to guess that you don't look underneath too many cars at the local car shows in your area. Don't get yourself too "rankled" but most legally titled older cars with classic car plates or antique car plates with "custom exhausts" have no catalytic convertor on them. If they have regular plates indicating that they need a state inspection including emissions testing, then the law you speak of is correct.
Old Apr 23, 2012 | 05:11 AM
Cliff Harris's Avatar
Cliff Harris
I got the random SES light during cruising because my EGR solenoid had failed and the EGR valve was frozen by carbon. You need to look at the whole system before just replacing the EGR temperature switch, which might not be the problem.
To Check engine light once in a while?
