Broken air intake housing
Old May 20, 2002 | 12:08 PM
rats87's Avatar
rats87
Default Broken air intake housing
I recently bought an '87 that has the air filter lid hanging on by one screw because it was over tightened and broke the intake housing. Is it worth looking into a higher performance intake housing and if so does anyone have any preferences?
Old May 20, 2002 | 01:27 PM
VetBoy89's Avatar
VetBoy89
Default Re: Broken air intake housing (rats87)
I had the same problem with my 89. As a temporary fix I drilled a small hole in the plastic base unit and used a tie wrap to keep the lid in place. Then I bought a new base on eBay for $30. Otherwise you can get the whole stock assembly for about $75 new.
I'm sure others will chime in about aftermarket systems.
Just my .02 :yesnod:
