Clutch Pedal Position Sensor
Old Apr 24, 2012 | 01:47 PM
keepers15's Avatar
keepers15
Default Clutch Pedal Position Sensor
I have a problem with my clutch pedal position sensor. Once in a while it will not let the engine start, (this part is discontinued #100458220. I ran a jumper wire and the engine will start. Does or will this cause any damage to the security system? Thanks in advance for your input.
Old Apr 27, 2012 | 01:08 PM
keepers15's Avatar
keepers15
Old Apr 27, 2012 | 01:09 PM
94z07fx3's Avatar
94z07fx3
Jumper is fine as long as you remember not to attempt a start while both in gear and clutch engaged.
Old Apr 27, 2012 | 03:52 PM
383vett's Avatar
383vett
One of the first mods I made with my 84 was to bypass the switch with a jumper wire.
To Clutch Pedal Position Sensor
