Leaking coolant
Old Apr 26, 2012 | 09:51 AM
Qiken's Avatar
Qiken
Default Leaking coolant
My 89 was sitting for about 4-5 weeks without being started
On starting it and it started to warm up.i noticed the coolant dripping on the ground underneath the lower radiator hose area,dripping out of the small hole in the housing the radiator slides into.
I checked hose clamps but it was fine,due to the cover around the radiator I cannot see where it coming from....Is it common for the plastic drain plug in the radiator to leak?? I checked and seemed tight..
Any suggestions this radiator is only a couple of years old.
Old Apr 26, 2012 | 09:55 AM
VetteMed's Avatar
VetteMed
drain plug shouldn't leak unless it was overtightened.
the plastic end tanks are prone to cracking, so I'd have to be suspicious of that.
Also can be the gasket between the core and an end tank, or the core itself (not likely unless damaged or poorly maintained)
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
Is it all-aluminum or is it the one with the plastic side tanks? One of the tanks could have started separating and lost its seal.
Get a coolant system pressure tester and press it up to the pressure stated on the cap. This will help you find where it's coming from.
Old Apr 26, 2012 | 05:52 PM
Qiken's Avatar
Qiken
Thanks Guys,
Will get it pressure tested,
Remember now
Only the core was changed,plastic ends reused.
To Leaking coolant
