1989 Corvette Power Window Switch
Old Apr 29, 2012 | 10:07 AM
Red89'-L98's Avatar
Red89'-L98
FL Events Coordinator
St. Jude Donor'13
Default 1989 Corvette Power Window Switch
So, my old switch broke and I took it out and now I am trying to install the new one I just got and I can not no matter what I do get it all the way connected. Can someone please explain what to do?
Old Apr 29, 2012 | 11:08 AM
caddyboy84's Avatar
caddyboy84
Make sure nothing is obstructing the holes and try some dialectric greese.
Old Apr 29, 2012 | 11:12 AM
Red89'-L98's Avatar
Red89'-L98
St. Jude Donor'13
I don't think that is it. I just can not get enough pressure on the little cord to plug it in and the way I tried to do it what with string and then pull o0n the string while pushing down on the switch but the string would break after so much pressure.
Old Apr 29, 2012 | 11:20 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Are you having problems due to lack of access? Or did you remove the console?
Old Apr 29, 2012 | 11:22 AM
Red89'-L98's Avatar
Red89'-L98
St. Jude Donor'13
Lack of access I guess and no I did not remove the console just the trim/bezel
Old Apr 29, 2012 | 11:30 AM
caddyboy84's Avatar
caddyboy84
What you're trying is a little unconventional, but try a piece of wire and try not to break anything. I'd just take the console apart to do it right, ya might create more problems.
Old Apr 29, 2012 | 12:17 PM
Jimbo 89's Avatar
Jimbo 89
much easier and not that time consuming.
GREGGPENN's Avatar
GREGGPENN
Let's see...The console's bezel is what the switch fastens to. IIRC, the problem is you can't get (or have a hard time) unplugging everything to lift the bezel high enough for access. Is that it?
Did you know the whole console comes loose by accessing a couple of bolts down thru the "glove box"?
Or, you could remove one of the seats and a side panel. (Might also be necessary for console removal...I can't quite remember w/o checking my FSM.
Old Apr 29, 2012 | 03:14 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
When I installed a new sw in my '88 I was able to get the socket worked up through the hole; yes it was a very tight fit and took some "wiggling". Again care is needed to not break any of the plastic.
To 1989 Corvette Power Window Switch
