See mods in sig.. I am looking into upgrading my cam, to something that will give me more power, but is still streetable (I am not opposed to a new chip along with the cam, but remember, this is my daily driver..). I am seriously considering the Hotcam kit, but am open to suggestions. What exactly would I need to upgrade the cam? Do I need new rockers?? Do I want to go with 1.6 rrs or 1.5?? What is the difference?? New push rods?? How difficult is it to change the cam?? Is it a job that can be done in a day with the right tools?? Wow, I just realized that I put 2 ?s at the end of all my questions.. :cheers:
I hear the zz-9 is a very streetable cam and makes good power. I am researching this myself. However I am on more of the wild side since it isn't my daily driver. I'm sure others will jump in I know the LT4 Hot cam is popular on here as well!
I went with the Hot Cam in my LT-4 along with some minor home style head work :D . This car is my daily driver and I can honestly say that there are no problems that I can see, my car is very streetable. The only thing with an LT-1 is you may need to tune the ecm for the brest results. Just a couple of things, you will notice you may have trouble driving slow under 2500 rpm as the car seems to lope along with the cam, as well I make an extra effort to stop at yellow lights so I can listen to the idle :yesnod:
:cheers:
comp cams also has a new line of cams out that totally rock, something between a zz4 cam and hot cam would be about ideal for a daily driver..like a fast ramp 214/222 or so
Which is a more extreme cam?? The Hotcam or the zz4?
Mark..the hot cam is extremely streetable.. anything less is not worth the money for gaskets.. your car will not be much different except for id;ing about 200 RPM higher with tuning.. gas mileage should remain civil and street manner will be fine... A/C operation normal etc... etc.... but the gains when you open her up on the top will be much more rewarding!
From: Phx/but its a dry blast furnace kinda heat AZ
Re: Upgrading my Cam.. (MarkLT1)
It's times like these, I *almost* want to live back east again....... Not!!! :D
I'll be installing this cam also, hopefully in the not too distant future. Should we be looking at the HotCam kit or just the cam with other (better) rockers, etc...?
FWIW, Sam @ Fairway Chevy (Las Vegas, NV) sells the kit for $500
