Interior Lighting Mod?
Old Apr 29, 2012 | 01:01 PM
Roadrashfly's Avatar
Roadrashfly
Default Interior Lighting Mod?
I'm new to this Forum so I have yet to figure out the placement of everything but i was wondering if changing interior OEM Bulbs to LED has been done and is possible? All the help I could get would be Great
Thanks in advanced
Old Apr 29, 2012 | 02:13 PM
hitmanpty's Avatar
hitmanpty
welcome to the forum. yes you can do that. with out a problem. just use the correct lightbult
Old Apr 29, 2012 | 02:21 PM
caddyboy84's Avatar
caddyboy84
Thanks in advanced
They make self contained LED bulbs for all interior applications but they are a little bigger than regular size bulbs and might not fit in every fixture. The P/O of my car had a "brite" idea and changed some bulbs to higher energy BRIGHTER bulbs that started to melt some of the plastic housings, IDIOT!! I had to change them all, under hood, glove box ect.. The glove box fixture actally started to smoke with that HOT bulb in it. LED's don't get as hot, so it should be ok, but check that out first. Those plastic fixtures are meant for certain bulbs and as usual sometimes things should be left "as is".
Old Apr 29, 2012 | 02:58 PM
Roadrashfly
Some people just can't read labels, I understand that, wattage and so forth I should have no problem with that but the thing that has me stuck is that I have no clue how to open the light bulb "casing" (you can say) on the door panels. Do I have to dissemble the whole door panel? If so how?
Old Apr 29, 2012 | 03:47 PM
caddyboy84's Avatar
caddyboy84
Most of the time, they pry off with a little screw driver, be careful though.
Old Apr 29, 2012 | 05:14 PM
phlounda's Avatar
phlounda
You can look up the bulbs by year and make
http://www.superbrightleds.com/cgi-b...sp=%2F1157.htm
Old Apr 29, 2012 | 06:33 PM
Roadrashfly
Thanks guys!!
Old Apr 29, 2012 | 11:20 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
r u sure? thought u needed 2 pull door panel 4 that 1....
the lens housings r screwed into the back.
Old Apr 29, 2012 | 11:24 PM
caddyboy84's Avatar
caddyboy84
WOW!! That sucks. My lights are fine on the doors so I never had to mess with them, I would've assumed the lens would pry off. Thats crazy to have to take the panel off to change a bulb, I'm gonna have to change that on my car. Nothing a Dremel or small dots of velcro can't fix.
Old Apr 30, 2012 | 12:11 PM
Deepa's Avatar
Deepa
Corvettehid has kits to do the whole interior. Google them
Old Apr 30, 2012 | 03:32 PM
VetteMed's Avatar
VetteMed
for 90-96, the door panel lights are secured with two clips along the uppermost edge, release with a thin flat bladed screwdriver. They are NOT screwed in.
Old Apr 30, 2012 | 05:25 PM
Roadrashfly
How about an 86'?
Old Apr 30, 2012 | 07:52 PM
VetteMed's Avatar
VetteMed
How about an 86'?
I have no experience with an '86, or '84-'89 for that matter. Someone else will chime in soon, I'm sure.
Old May 1, 2012 | 01:34 PM
IAFF alumni's Avatar
IAFF alumni
A 2 page thread on the subject can be seen here:
http://forums.corvetteforum.com/c4-g...light-kit.html
Old May 2, 2012 | 09:26 PM
Roadrashfly
Thanks bro!
Old May 2, 2012 | 09:30 PM
Roadrashfly
But then again, it does not tell me if I have to disassemble the door panel?
Old May 2, 2012 | 09:33 PM
IAFF alumni
The bulbs in the door panels can be accessed by using a small screwdriver and carefully prying the cover out.
It is only held in place with a couple of nubs, and deflecting it with a screwdriver is all that is needed.
At least, that was all that was needed on my 92.
To Interior Lighting Mod?
Old May 2, 2012 | 09:38 PM
Roadrashfly
I'll try that tomorrow morning then, how long does it usually take to receive your package from CorvetteHid or Superbright?
Old May 2, 2012 | 09:41 PM
IAFF alumni
Depends on what shipping you selected.
Generally 5 to 7 days using USPS priority mail.
Old May 2, 2012 | 10:02 PM
Roadrashfly
Guess im ordering tonight !
