Battery replacement precautions
Old May 20, 2002 | 11:23 PM
Harry Zientek's Avatar
Harry Zientek
7th Gear
Default Battery replacement precautions
I will be replacing the battery in my 1993. Anything I should do to avoid any computer or electrical problems?
Old May 20, 2002 | 11:28 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Battery replacement precautions (Harry Zientek)
I recently had mine out to clean the battery and it's surroundings. I just pulled the "-" lead first, then the "+" lead and finally the panel and battery.
You could plug one of those small battery kits into your lighter to save the radio & clock presets.
Old May 20, 2002 | 11:30 PM
SmokinBlack's Avatar
SmokinBlack
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
C4 of Year Finalist (stock) 2019
St. Jude Donor '08
Everything should go as normal. Try not to "spring" the fiberglass when removing the side panal.
Old May 21, 2002 | 12:34 AM
VAHROOM's Avatar
VAHROOM
Default Re: Battery replacement precautions.
I took a little extra time when i did mine. I pulled the battery box out and cleaned it. I also washed out the general area with baking soda. Then wire-brushed the frame there. I painted the area with a corrosion preventive paint and then topped it off with the black frame paint. Since I own a 90 I removed the DERM and cleaned under it and used dielectric grease under it. I also cleaned all the wiring connections and made sure all was well before putting the fender (if you can call it that) back on.
Good Luck,
V
chucks88's Avatar
chucks88
Default Re: Battery replacement precautions (Justin Gillott)
:confused:
Old May 21, 2002 | 01:08 AM
JonM's Avatar
JonM
Here you go Harry...click here http://www.corvettemagazine.com/2001...ttery/bat1.asp
To Battery replacement precautions
