Still no cig lighter?
Old Apr 30, 2012 | 07:07 PM
C4vettrn's Avatar
C4vettrn
Default Still no cig lighter?
I posted awhile back that my cigarette lighter wasn't working. I found the fuse for it and thought that would fix it (was fryed). I also took it completly apart and cleaned all contacts etc. Stil not working! could the lighter itself be bad? I need to get this working before I get a flat and need my tire pump.
I guess I could always wire the pump with some alligator clips end go straight to the battery but I would realy like to figure it out. the manual gives nothing on checking voltage or any trouble shooting.
Old Apr 30, 2012 | 09:21 PM
HlhnEast's Avatar
HlhnEast
Replacement units are available at most auto parts for cheap. Put a new one in and find out.
Old Apr 30, 2012 | 10:39 PM
caddyboy84's Avatar
caddyboy84
Try taking out the fuse and bend in the ground tangs inside the lighter port, theres two of them. Repaired a thousand lighters over the years and I have a dozen laying around as spares. Go the local salvage yard and just pull out a lighter. Do you have power at the port? Check it with a tester, then you know it's the lighter itself. If you want a new one they're pretty cheap in the help section at AutoZone.
Old Apr 30, 2012 | 10:46 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
Have you tried plugging the pump in??
Old May 1, 2012 | 06:37 PM
C4vettrn's Avatar
C4vettrn
WTF! know why didn't I think of that I will do that and see if it's not the part that plugs in being bad. I usualy think of obvious things like that but you got me this time
To Still no cig lighter?
