Could someone please shed some light on my brake switch wiring. I need to figure out how to wire my LSx TCC. I need a NC connection to make it work.
I found what I needed Thanks Jack
In this diagram you can see the brake switch wiring pink hot then feeds purple when the switch is closed its 12V when you step on the brake the switch opens. This will be hooked to Blue 33 for TCC lock up. When I took out the 700r4 wiring this was the only wire that I did not know what to do with I'm glad I saved it and made a note.
