ASR ABS Warning Lights are Active
Old May 2, 2012 | 10:38 AM
VolMan's Avatar
VolMan
Default ASR ABS Warning Lights are Active
Good Morning Everyone. I have an issue with my 1995 LT1 Coupe with 220K miles. I would welcome the feedback of the members here before I take the Vette to a garage. My concern is that with this problem, it would turn into a "research project" and he would bill be plenty. I know well about the "corvette tax".
The Service ASR, ASR off, ASR Active, ABS Active, and Service ABS warning lights become active upon ignition. After the Vette begins to roll, either in drive or in reverse, after a few seconds, the ASR Active and ABS Active warning lights turn off. The Service ASR, ASR off, and Service ABS warning lights stay on all the time. The ASR button on the dash has no impact on the warning lights. There is no event or other problem that I can relate to this problem. The Vette seems to drive just fine, as it always has.
As additional information, since this has occured, the brakes have been replaced, and the hubs have been replaced. In fact, and perhaps I am incorrect in this, I am disappointed that when this work was done the shop did not address these warning lights.
Any thoughts as to cause of the warning lights?
Thank you.
Old May 2, 2012 | 03:58 PM
bac22's Avatar
bac22
Shop wouldn't address those issues unless you asked them too. ABS is not a required function for the brakes to work, and ASR has nothing to do with the brakes.
First thing you should do is pull your codes and see if it points to something specific. It could be anything from a wiring short providing false readings to a bad control module. I'm sort of leaning towards the control module since it's indicating both ABS and ASR are having a problem and I believe the same control module handles both.
Old May 2, 2012 | 07:37 PM
94z07fx3's Avatar
94z07fx3
Thank you.
I can guess. I suspect a wheel speed sensor is AFU.
But we don't have to guess.
Read the trouble codes for module 9 and post them here.
(How to read the codes and other things in case you need the link.)
http://forums.corvetteforum.com/c4-t...n-96-cars.html
To ASR ABS Warning Lights are Active
