Cassette adapter keeps ejecting in my AC Delco radio
I had the same issue. The cassette adapter kept reversing then ejecting in my AC Delco radio/cassette CD player.
Here is the fix. At least that I know for an AC Delco (GM) radio cassette.
Ignition ON
Radio OFF
hold the TAPE button for 3-5 seconds.
The little cassette logo in the display will blink. At that moment push the cassette adapter in.
Viola!
Cassette to iPod adapter will work no matter which brand you use.
This was actually GM/AC Delco's way to be able to clean the head with one of those tape head cleaner cassettes.
Let me know if that fixes your iPod issues.
BTW this sounds 100x better than the FM transmitters.
Reason: Forgot the title of my reply
I have converted several tape decks to ipod receivers for free. take the deck out, get to the casette head, snip the 3 wires on the head (usually Red, Black, and gnd) and re-connect to a female mini headphone jack that you will plug in to the ipod headphone jack (Red is Right, Black is Left, Gnd is Gnd). run the cable out the radio somewhere to where you can access it and plug your ipod (I use my laptop because it holds more music). when you turn the deck on, it will get the signal through the jack, you'll need to adjust the volume on the ipod pretty low to where you are not overpowering it (you'll know because it will sound like crap). The ipod won't charge, but you'll have a dirt cheap ipod capable stock system, just won't ever be able to play tapes again...I first saw this in the instructables site and was skeptical but it does work well.
That sounds real interesting. No offense to doctor don but I don't have the 200 bucks for an installed jack and I don't want to rip out my entire bose system untill i've got the money to replace the carpet, trim, insulation AND sound system all in one go. Do you have the link to the instructables?
anyone had this same success with the bose gold from 85?
Thanks for the tip on using the Cassette player. I was trying to use a cassette adapter that pulgs to my iPhone so I can use Pandora, and it was always being ejected. I tried the technique of turning off the radio and pressing cassette button for 5 seconds, inserted the cassette adapter after the tape icon appeared, and VOILA!!, it worked. You saved me hundreds as I was about to replace the stock. Thanks again!!
Ignition ON
Radio OFF
Viola!
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Originally Posted by caddyboy84
Those things don't work. Once I tried to "cheap out" and got a cd adapter for my radio and it sounded like crap and had no volume, so I just ripped out the system and bought some decent stuff. Do a modern cd radio with an I-pod jack. It's easy to put in a radio, use the Bose speakers and just bypass the amps and work the speaker boxes from the radio amp.
Did you ever really try one? I ask because cassette adapters certainly do work
I tried several cassette adapters, but the one that really works is the Monster iCarPlay 800 Cassette adapter. Very very minimal noise interference, because of the spring loaded head. Just my two cents.
Ignition ON
Radio OFF
Viola!
I believe i have the same radio in my '87, but i can't seem to find the "TAPE" button. I have EJECT, FWD, and REV buttons for the tape. my radio has two lights next to the word Tape that shows the direction.
His is not a stock radio as he said there was a CD in his
