Chip or no chip?
Old May 5, 2012 | 05:24 PM
Z5185C4's Avatar
Z5185C4
5th Gear
Default Chip or no chip?
So just installed a new engine, TFS heads/zz2 cam/24lb accel, superram, etc. The car runs but does not sound/run healthy unless under WOT. I keep hearing different responses but my question is
should the car run fine without getting a custom chip made? or is it necessary to get a custom chip made because of the heads/cam/etc?
Any help extremely appreciated!
Old May 5, 2012 | 10:31 PM
ntanzi's Avatar
ntanzi
Default Yes.
With all of those modifications, you will most likely need a custom chip.
There are a few places you can get one made:
http://tpis.com/pages/efi
http://www.boosperformance.com/c4l98_cust_chip.html
People may know of cheaper/better places. TPiS has been dealing with the L98 for quite sometime though and I trust them over most.
Or you can begin the quest to tune your own chip. I have chosen to do this with my 87. It can be fun but very frustrating. But for early C4's it's only about $100 on chip burning equipment that looks like this:
http://forums.corvetteforum.com/c4-p...ing-burn2.html
Then you will need to attach a new reprogrammable chip to your MEMCAL. But you can find all of this fun stuff out by reading various forums.
But once again, you will most likely need a custom chip. And remember generic "Hypertech Stage II" chips will not help or fix the issue. You will need to tell someone exactly what has been done to the car so it can be made for your car. If they don't ask what has been done to it, you are wasting your money. Good Luck!
Old May 6, 2012 | 03:46 AM
rodj's Avatar
rodj
Radical departure from stock config.
Custom tune certainly needed
PCMforless
http://pcmforless.com/index.php?opti...d=91&Itemid=29
are popular for tunes ( price includes the custom chip adapter )
zz2 cam
Why that cam?
GMPP #10134334.
235/235 .480/.480 114LSA.
Lots of duration but no lift to match the heads Not the most EFI friendly cam
Old May 7, 2012 | 12:37 AM
Tunedport90's Avatar
Tunedport90
PCMforless
Why that cam?
GMPP #10134334.
I would opt for a better cam as well. Make sure you deal with a company that you can send in a data log too so they can correct the LV8. A better choice would tobe to convert to sd and go with dynamic efi ebl p4 it will learn your lower and upper ve tables. save all the testing and retuning.
To Chip or no chip?
