Old Gas
Old May 7, 2012 | 09:28 PM
myredvette87's Avatar
myredvette87
1st Gear
Default Old Gas
I have had my Corvette in garage for the winter without starting her up. I was wondering if that was bad, and how long can gas sit before its bad and what do I do about it. I don't want to screw anything up on her. I want to make sure that if I sell her I won't have fuel problems when going for a test drive with a potential buyer. Please help.
Old May 7, 2012 | 10:28 PM
mtnmanut's Avatar
mtnmanut
Gas usually turns in about 3 months , unless you have added a fuel additive such as stay-bil and that can extend to maybe six months. smell the fuel,if it has the kerosene smell,get it out. if not and the tanks not full ,head straight to the nearest gas station and fill up with the highest octane they have. next ,get in your vette and drive. and don't forget to put on the big vette smile as your driving. cruise and enjoy.
Old May 7, 2012 | 11:18 PM
JackDidley's Avatar
JackDidley
Ive run year old, untreated gas, no problem.
Old May 7, 2012 | 11:41 PM
84VetteMan205hp's Avatar
84VetteMan205hp
i have ran 17 year old gas in my 80 camaro and it was fine it just stalled and you could smell the old gas. i would not recommend doing that but your gas should be fine just add a little fresh gas and run the old gas out
Old May 7, 2012 | 11:47 PM
cv67's Avatar
cv67
St. Jude Donor '05
drive it
Old May 8, 2012 | 12:39 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Old May 8, 2012 | 02:49 AM
Shock96's Avatar
Shock96
Also agree. I have run 2 year old fuel and it didn't cause any issues. Just add some fresh and it should be fine.
Old May 8, 2012 | 06:09 AM
93 ragtop's Avatar
93 ragtop
I used to fill mine up before putting it away for winter. Come out in spring and never have any problems.
Old May 8, 2012 | 06:25 AM
milsurpman's Avatar
milsurpman
stabil will keep the gas alive for a year in a big dose. Any more and your asking for it.
Old May 8, 2012 | 08:39 AM
Chuck Tribolet's Avatar
Chuck Tribolet
I think it's a function of how full the gas tank is. If the tank is just
about full, there's nothing for the gas to react with. My '87 gets its
usual workout at Christmas to go to Tucson (2000 mile round trip) to
see my mom. It's pretty much sat all year with a full tank, no problem.
This year bad tires and a bad master cylinder kept it in the garage at
Christmas, but that's all fixed now. We drove it out to dinner Tuesday,
no problem.
I just went out and pulled the gas cap. It smells like gas, not
kerosene after pretty much sitting for 16 months. I'll be driving it to
work sometimes to run the gas out and get a fresh tank in before we
drive to Tucson in June for mom's birthday (big milestore).
If you have a quarter tank, there's less gas for the bad stuff to react
with, and more volume for air and humidity in the tank. And, changes
in atmospheric pressure will pump air and humidity in and out of the
tank.
Old May 8, 2012 | 10:40 AM
H Watkins's Avatar
H Watkins
St. Jude Donor '15-'16, '21,'24
[QUOTE=Chuck Tribolet;1580755625]I think it's a function of how full the gas tank is. If the tank is just
Old May 8, 2012 | 10:58 AM
1991Z07's Avatar
1991Z07
Actually, it's a function of the fuel in your area and what grade is in the car.
Super (in Texas) has ZERO ethanol in it. The other grades do. If I have Super in the tank, I have no problems leaving it over the winter.
Fuels with ethanol break down and leave varnish deposits. Injectors are the worst areas for it to cause problems...sticking and such.
IF you used fuel with ethanol, fill it with super and some injector cleaner and drive it. I'd use the cleaner for a few tanks...just to ensure they are cleaned out.
Old May 10, 2012 | 06:56 PM
01 red Vette's Avatar
01 red Vette
Would bad gas make the injectors randomly shut of? Like 2 & 6 may stop working shut it off & crank it back up & 3 & 8 may stop working.
Old May 10, 2012 | 07:21 PM
1991Z07's Avatar
1991Z07
Not directly...
If they are gummed up then it is because the fuel degraded and left a sticky deposit on the pintle/seat of the injector.
So some of them could randomly stick open or closed based on that.
Some injector cleaner will certainly help...
Old May 10, 2012 | 08:23 PM
01 red Vette
Well i took it to the chevy dealership and they cleaned the injectors and its still doing it. They couldn't figure it out . so i just went and got it from them. Do you think it could be the computer?
To Old Gas
