Best ICM
Old May 8, 2012 | 10:29 AM
choopes's Avatar
choopes
Default Best ICM
I see a lot of different brands at different prices. Whats the best ignition control module to get for my "93 coupe? I want one that will hang for a while, as these seem to be a problem with these cars. What have you had good luck (or bad) with a particular brand of ICM?
Old May 8, 2012 | 11:18 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
well - first you need to make sure it is your problem.
I thought mine was eating them - turned out it was the cable connection on the passenger side intake. The connection between the opti and ECM.
Make sure you ALWAYS use heatsink/thermal compound between the ICM and the heat sink.
Other then that I haven't found any I would call excellent. O'Riely seems to work the longest so far
Old May 8, 2012 | 07:15 PM
93Rubie's Avatar
93Rubie
To add to this. I got one a while back from Advanced Auto Parts it was a BWD brand ICM. I looked on the box label and the darn thing was made in the USA. I could not believe it!!! I never used it and took it back.
Might want to give it a try if you determine it is bad. I bet the AcDelco one is made in China. Go figure.
Old May 8, 2012 | 07:30 PM
WW7's Avatar
WW7
They were trying to pawn that American made crap on you, no wonder you took it back.......WW
To Best ICM
