Rotate VSS 180*?
Old May 8, 2012 | 11:46 PM
69SSC5's Avatar
69SSC5
Default Rotate VSS 180*?
I have read on here and other forums that if you have the 39T or less VSS and need the 40t plus vss, you can rotate the 39T vss and it will work like the 40t + vss. can anyone confirm this? thank you
note: i have the 17T drive gear, the 44T driven gear but i need the 40T+ VSS and i only can get a hold of the 39T- VSS
Old May 9, 2012 | 02:40 AM
69SSC5's Avatar
69SSC5
sorry forgot... 89' 700r4
Old May 9, 2012 | 11:18 AM
69SSC5's Avatar
69SSC5
morning bump...
Old May 9, 2012 | 05:22 PM
69SSC5's Avatar
69SSC5
anyone???
Old May 9, 2012 | 06:01 PM
96GS#007's Avatar
96GS#007
Never heard of such a thing.
The VSS bolts to the tailshaft and the gear spins. Doesn't matter what the orientation of the VSS is.
Old May 9, 2012 | 06:16 PM
James93LT1's Avatar
James93LT1
Veteran: National Guard
http://www.corvetteforum.net/c4/vett...Gearshtm.shtml
Old May 9, 2012 | 09:16 PM
WVZR-1's Avatar
WVZR-1
Originally Posted by Heimlich2010
anyone???
NO! -
Now - I believe what I'd do is use a 15 tooth drive with a 39 tooth driven and you'll be pretty much where you need to be. In your earlier posts I assumed you wanted to use 17 because it was already installed, your more recent posts seem to indicate you've bought new drive/driven and are ready now to do an install!
Do you have a good less than 40 VSS (25007224)?
Probably less than $20 worth of parts!
8642620 (gray) drive
25513046 driven
Old May 9, 2012 | 09:25 PM
matts85vet's Avatar
matts85vet
i've heard of it.
the shaft for the driven gear is not directly in the center of the vss, it is offset slightly. thus when rotated 180 degrees, it will move the center axis of the driven gear farther away from the drive gear.
this will allow you to use the larger driven gears with the same vss.
the bracket that holds the vss won't fit as well, but it will work.
if you decide that you want a vss for the 40t and up driven gear, you can buy it from here:http://www.transmissioncenter.net/sp...n_______va.htm
i bought one of these when i changed gears to 3.75 and needed to use a 45t driven gear
Old May 9, 2012 | 09:34 PM
WVZR-1's Avatar
WVZR-1
Originally Posted by matts85vet
i've heard of it.
Yes - you've heard of it but "hearing of it" doesn't make it a "proper or even possible" fix! I saw this mentioned and recommended to someone on another forum and his response was the "genius" who dreamed this up was actually quite an "idiot" ! I'm not sure of the original source but if it's from the source that I've been told in the past that it's from yes he's got issues!!
To Rotate VSS 180*?
