LT4 Timing chain
Old May 21, 2002 | 08:47 PM
Rolla Dunkin's Avatar
Rolla Dunkin
Default LT4 Timing chain
If I replace the water pump with an elec. one will a after market double roller chain fit under the stock timing cover,as it looks a little shallow. :cheers:
Old May 21, 2002 | 10:07 PM
GlockLT4's Avatar
GlockLT4
Default Re: LT4 Timing chain (Rolla Dunkin)
Nope.
[Modified by Glock'94, 8:08 PM 5/21/2002]
Old May 22, 2002 | 06:14 AM
93 ragtop's Avatar
93 ragtop
There is a guy on this forum named Nathan and I believe he did exactly what you are asking. He used the standard chain set since you dont need the water pump drive anymore. Last I seen he was now converting to a pete jackson drive set up. Anyhow, do a search on his name and I believe you will find what you are looking for. I do remember him saying that the offset of buying the electric pump was saved in the chain set.
To LT4 Timing chain
