Can someone please take a pic of the vacuum lines on a 94-96 LT1 on the back side of the intake (passenger side around the check valve/pressure reg) including the lines going into the firewall.
Found out that a little critter got under there and apparently had a taste for the vac lines. Some of them are completely eaten away.
Do they make some sort of coupler for vacuum lines or do you have to replace them as a whole solid line?
I own an FSM btw - but would like to see pics to be sure.
Not sure if this will help, it shows the check valve on my 93. The top vacuum line in the picture connects to the fuel pressure regulator, one of the lines coming off the check valve goes to the HVAC system, the other one supplies the cruise control servo.
