Need help - new stroker build to high AFR
Hi all..
I need some assistance..Link is a downloadable Datamaster logg.
http://dl.dropbox.com/u/52503631/first.uni
I have installed a Innovative wideband lambda in my Vette. The engine is a newly build 383 stroker, Trickflow heads and cam. The tune for the car is done by PCM4less.
Picture of one of the spark plugs is here : https://lh5.googleusercontent.com/-Q...5-k/2012-05-12
The readout from the lamda says that car is going far too lean. For the moment I have only 1 gear (some problems with rebuilt transmission). I did a small testdrive today and logged engine data with TTS Datamaster. The Innovative lambda sonde shows a AFR about 16-17 (which is to lean). The AFR when engine is idling is even higher (above 20).
Fuel pressure is about 45-50 psi..
Injectors are 32 lb/hr (Bosch design III from FIC) and the all measure 17.3 ohm..
I do not understand all datamaster readings. Can someone please help me and give me some feedback. Dont know if fueltrim values says anything about AFR..
Rebuild is here : http://thomas-chevy-c4.blogspot.com/
Where did you get your tune?
Doesn't Alvin do free re-burns to dial it it? I'd send both your logs to him and get a new chip.
HOWEVER, where is your wideband located and does it seem to match up with the datalog BLM/INTs?
I ask because an exhaust leak before the wideband will make it look leaner than it actually is. So if you have the bung after a junction, you could be seeing that effect. Just make sure that isn't a problem before you dig too deep into this.
You do know you have a canister purge error code too? Not sure if you're getting too much air in the purge line if it's hooked up, or if its not hooked up and not tuned out..
And thanks for your replies - the members at US Corvette forum is as always, very responsive ..
Best regards,
Thomas
We do need to know this.. According to the datalog, your left bank (Drivers side) is running lean, while the right back appears to be running ok. Could be a bad injector, injector plug, spark plug, plug wire or exhaust leak on one of the left hand cylinders
Thanks for info, learning every day ;-)
I don't know if you have cats, but if so, multiple leaks + cats could mean your tune is just fine.
A single leak ahead of an o2 sensor in the y-pipe can cause AFR drift of 1.5-2 at WOT. Your scenario sounds like it could easily cause it to drift from 12 to 16.
Good luck and let us know what Alvin says. He will be looking at the BLM/INT data.
Better yet can you move it up into the header collector or at least in the y-pipe before the cat so there is only one junction before the o2. Similar to where the factory front ones are. Another thing, are the exhaust leaks new? I notice you said it was fine on your old tune?
The O2 sensors connected to the ECM is located at the collectors. I dont how accurate they are compared to the heated sonde from Innovate. The stock O2 sensors (which are new) are not heated..
I will report back about what Alvin (I suppose he is PCM4less ;-)) says about DM log..
So the leaks were there when you got the 12.5 AFR reading at the same port?
Then it is at least partially your tune. If they leaks are new, they could be a contributing factor.
It sounds like you are on the right track with Alvin checking. Do let us know what he says.
I will fix the leaks on Tuesday when getting the car back from workshop. In the meantime I probably have a respons from Alvin/PCM4less as well ;-)
I`ll post results here, thanks very much for responses to my thread..
Best regards,
Thomas
Have been in contact with PCM4less - waiting for an answer from them. Anyway - I have fixed exhaust leak (at least to a minimum). Stil I think the engine is somewhat lean.
In open loop the AFR is 11.2 - 11.4. As soon as engine goes into closed loop AFR is between 15 - 16. When accelerating AFR goes down to about 14 (and maybe 13). A fellow corvette friend asked me what about fuelpump? Dont know how old my fuelpump is - but as long as AFR in open loop is quite rich I dont think there any problems about fuelpump not delivering enough..
Will post answer from PCM4less when it comes. I might ask him for a tune which gives me a AFR about 13-14?
Regards,
Thomas
Regards,
Thomas
Got an reply (and new tune) from PCM4less... He says "Here is a new file for you. Something is off somewhere. What injectors are in the car? What is the fuel pressure? What is fuel pressure under wide open throttle?"
"Something is off somewhere"... Can anyone with knowlegde about Datamaster and logging please have a look at the attached DM log and help me out? I have asked him what he mean about this ...
http://dl.dropbox.com/u/52503631/andre.uni
With the 92/93 the IAC can be bad and cause a false lean as it will cause more air to come in. The IAC will not give you a code. It needs to be unplugged at a minimum and read with an ohm meter. I had an IAC "leak" as it was broke for a long time, but since there was no code, I never knew it. It is a controlled vacuum leak after all. There are write ups within this forum showing you how to test the IAC. Alvin is pretty good.
I think what Alvin is getting at, is that you are running quite rich at idle but yet going lean on WOT. At idle you are using FAR less fuel than at WOT, so if you have a pinched fuel line, clogged fuel filter, dying pump etc that limits your flow under high demand, this fits and could explain a problem of an overly rich tune still going lean at WOT (which is what I think Alvin is getting at.)
This.
The FAT part at idle is in open loop. As soon as closed loop idle is also somewhat lean...
