"Engine Service", code 21 and 64
Old May 22, 2002 | 12:09 AM
vette&fun's Avatar
vette&fun
Default "Engine Service", code 21 and 64
Need help with these two codes 21 and 64. First, I got the fuel pressure problem due to a bad fuel pressure regulator. Just replaced the rugulator couple days ago. Fuel pressure is now staying at 45-46PSI (which is good). Also, I reset the ECM by disconnected the battery cable for about 5 minutes after replacing the regulator. However, these two same codes are still there. I also have a performance throttle switch plugged on. Do not know if this switch is the problem that creates code 21. Thanks
