I have found this vacuum line just hanging there so I plugged it and now i am trying to find where the other end goes ? Photo is taken from the passenger side. This little port is right next to the MAP SENSOR.
Being the Cruise does not work and the AC vents do work properly it
would be nice to figure where it goes ?
I t seems I can not add a photo? am I missing something ?
The vacuum check valve is next to the distributor on the driver's side. One side goes to the HVAC system in the cabin and the other goes to the cruise control. This is what you're looking for:
The vacuum line that goes to the check valve comes from the rear vacuum port on the plenum (passenger side).
It's just to the left of the fuel pressure gauge in this picture. You can see that it goes around in front of the distributor (refer to the previous picture):
That means someone has most likely removed the valve and connected the HVAC line
from the firewall direct to the vac port on the plenum
Do your vent positions change when you accelerate?
