BBK 52mm throttle body question
Old May 14, 2012 | 06:02 PM
CorvetteC4CABRIO's Avatar
CorvetteC4CABRIO
Default BBK 52mm throttle body question
Hi,
I have a 52mm BBK throttle body (link with picture below) in my 1991 L-98.
http://www.bbkperformance.com/produc...?car_motor_key[]=1502&car_motor_key[]=1513
Does any one know for what is the gold hose conection that appears hidden in the upper left of the picture? My car had connected one of the breathers from the valve covers, but i guess that doesnt make sense since there is preassure being sent in opposite directions through that hose..
Thanks!!
Old May 14, 2012 | 09:23 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
[IMG][/IMG]
That is a throttle activated vacuum port, there is another, smaller port right below the one in question which is full time vacuum. If you don't need it just put a vacuum cap on it.
Old May 15, 2012 | 04:43 AM
rodj's Avatar
rodj
That is the supply air for the PCV system;
comes from in front of the butterflies hence it has no vac on it
Filtered air goes from that port on the TB to the pass side rocker cover , through the engine then out the PCV valve on the drv side cover to the intake.
When you accelerate hard and there is no vacuum to suck fumes through the PCV valve, the engine fumes go in reverse;
from the pass side cover, back to the TB and into engine to get burnt
Old May 15, 2012 | 07:27 PM
CorvetteC4CABRIO
Thks for the replies. A couple of questions based on what you are telling me:
Midnight85, how do i know if i need it or not? In case i do not, what is a vacuum cap? A simple cap that prevents de air going out from it?
Rodj/midnight85, how would you connect the hoses? I have 2 holes in the pass side rocker cover, 1 hole in the driv, the bbk throttle body and a procharger supercharger with a conic filter with a hole in it, suggesting there was some kind of hose connected there...
Dont i penalise performance buy sending hot oil burnt gases through the car's intake?
Thank you very much and sorry for my little experience in the subject!
Old May 15, 2012 | 09:07 PM
Midnight 85
[IMG][/IMG]Look at my first picture, you need the one that is hooked up in my picture. The one below it is constant vacuum and since I have no need for it it is capped with a rubber cap. Although it looks different than the new ones my throttle body is a BBK. I should add that my other side is exactly as rodj stated. I've added another picture of the driver side so you can see the vacuum hookup there. You have a port coming out of the intake between the runners, you can't see it that good but mine goes forward under the wire loom to a tee where the pcv taps in, the other side of the tee has a hose that runs up to the vacuum canister. I've done a lot of mods on mine but I believe yours should be exactly the same.
Old May 15, 2012 | 10:01 PM
leesvet's Avatar
leesvet
what burnt gases? oil mist/fumes can do nothing but help. They are minimal anyway. If it were a lot, you would be adding a qt of oil every day.
The penalty comes from NOT having the PCV system properly connected. The oil gets contaminated, sludge forms, moisture stays in the crank case, carbon accumulates, the engine becomes a toxic waste dump inside....so yeah, get it straightened out and help the engine live longer. PCV has absolutely nothing to do with anything except the life expectancy of your engine.
Old May 15, 2012 | 11:58 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Originally Posted by Midnight 85
[IMG][/IMG]
Old May 16, 2012 | 12:19 AM
rodj's Avatar
rodj
a procharger supercharger ..
You failed to mention that important little point
, how would you connect the hoses?...
Same as described above except the TB port will now be under pressure and need sealing up
With pressurized induction your PCV supply air has to come from before the SC ; hence the fitting on the air cleaner so supply air to pass side cover would originate there.
Old May 16, 2012 | 02:58 AM
Midnight 85
Originally Posted by GREGGPENN
Thank you.
Old May 19, 2012 | 06:27 PM
CorvetteC4CABRIO
My PCV system is a real mess.
I will definetely seal the upper port of the TB given is is supercharged
The lower por of the TB receive a hose coming from the gas tank with a valve near the passenger valve cover. Is this ok or should i cancel this, and seal the other port also?
Thks!
Old May 19, 2012 | 06:38 PM
CorvetteC4CABRIO
This is that valve i am talking about..
http://www.youtube.com/watch?v=BqawDo7P8vQ
Also, does anybody know if i should bypass this valve? I guess it is only to circulate some intake gases to the exhaust. It suck air form befor the TB so i guess it may be lowering the boost?
Any problem with removing it?
http://www.youtube.com/watch?v=2pTnZBbtsr8
Old May 19, 2012 | 09:11 PM
GREGGPENN's Avatar
GREGGPENN
That's called the EGR which isn't open during WOT runs. The EGR helps prevent detonation but isn't as necessary when using a cam with sufficient overlap. Otherwise, it's a good idea to keep it.
Kinda hard to image it's hurting your boost. I doubt it's causing any problem.
Old May 19, 2012 | 09:40 PM
CorvetteC4CABRIO
Thank you Gregg!
Would you also keep the valve on the second video? That is the one i suspect could be hurting the boost a little bit.
Old May 20, 2012 | 01:40 AM
rodj's Avatar
rodj
What you need to consider is that ports that are supposed to be vac ports
(like the tank purge port you mention ) may become pressurized when under boost.
Maybe a one way valve needed on the line to air does not go wrong way and pressurize something
The air injection goes into the exh manifold so it has no effect on engine or boost.Only there to clean up the emissions
Old May 20, 2012 | 05:55 PM
CorvetteC4CABRIO
Makes perfect sense rodj!! Thanks
To BBK 52mm throttle body question
