Quick rear end determination on 91?????
Old May 15, 2012 | 08:16 PM
nomad253's Avatar
nomad253
Default Quick rear end determination on 91?????
Hi guys I'm in the process of building a rear for unknown variant of a 91 I picked up at a junk yard bargain. All the aluminum is in great condition .fantastic even. So after I pull off the batwing is there an easy way to determine what I'm working with? When I spin the shafts there is a number on the main gear is 74224 x 6 18 91. Any info would be much appreciated.
Old May 15, 2012 | 08:42 PM
383vett's Avatar
383vett
Divide the # of teeth on the ring gear by the # of teeth on the pinion gear and you will have your axle ratio.
Old May 15, 2012 | 08:44 PM
96GS#007's Avatar
96GS#007
The ratio is typically stamped on the bottom (outside) of the case. If you have a D44, it's a 3.45. If you have a D36, it'll be numerically lower. The D36 ratios slip my mind but are something like 3.07 if it had the performance gears or a 2.59 if it had the base gears.
If it's not stamped on the bottom of the case, just spin the yoke and count the revolutions of the spindles the half-shafts bolt to.
To Quick rear end determination on 91?????
