86 sluggish cold starts
Ignition Coil?
(ICM) Ignition Control module?
From what i have read these 2 parts act up when hot??
Your thoughts would be appreciated
Ray
There is also a "pickup coil" under the distributor rotor. It picks up the magnetic pulses from the pole piece and turns them into electrical pulses. The pulses get amplified by the ICM. I have heard of the pickup coil falling apart. I guess that means that the plastic breaks. I think this is an old problem and the technology is better now so no longer a problem.
The ICM gets VERY hot. It needs to have heat conducting grease under it to help remove the heat. The grease fills in the air gaps, which are insulators for the heat. If the grease wasn't put under the ICM, I suppose it could cause a problem.
I have a vague recollection that there is a bushing kit that can be installed to fix this. I don't think it's something the average guy can do because it requires precision boring of the holes to get a press fit for the bushings.
I have a new ICM coming this week through EBay...will post results later.
gonna Vacuum test the EGR valve...could be sticking open a bit??
I think the diaphragm had a small rip that allowed the vacuum to leak but it wasn't large enough to affect the braking. I'll take it apart when the new one arrives and see what happened. I replaced the diaphragm about 15 years ago. Back then there was a split about 4" long. That one failed while I was driving on the freeway.
You could disconnect the EGR tube from the intake manifold. When I did that I stuffed a wad of aluminum foil into the pipe. It blew right out as soon as I started the engine, so there is quite a bit a pressure there (at least when the engine first starts -- it might be a lot less at idle).
What would disconnecting the EGR tube from the manifold do or prove?
If i suspect that my valve is staying slightly open during cold starts would i not have to "on car" test it with vacuum somehow. Cant even get a square little mirror in place to see if the diaphragm moves...too tight in there
Start your own thread. Thanks.
So first i disconnect the csv and try to start the engine, the problem was exact the same.
After that i checked the cold start switch with a volt- and ohmmeter.
I had 40 Ohm and both cables had electricity (csv - connector).
-> it seems the switch is ok
Next step was to remove the csv from the intake, only a small gap, to check for injected fuel. And there was no fuel while cranking!!
So i changed the memcal in the ecm from 1988 to 1989, and after that the engine starts fine.
I know you have tryed a 1989 memcal, but maybe you can check the csv in this way?
Now i have to find the vakuum leaks...
Best Regards,
Frank
Best Regards,
Frank
Becareful some FORUM **** might get his panites in a twist if you ask questions regarding your car on a thread you didnt start. See above.
Your comments about the "forum ****" are not warranted or welcomed...keep your shat to yourself.
Cliff Harris is another member who has offered his help and knowledge over and over again on this thread and this forum. His comments are very much welcomed...in this case c5autoxracer...yours are not
Installed a new ICM yesterday...this morning the car did not crank as long before starting...could be that the motor was still warm...been close to 100 degrees here the past few days...hot at night too.
Once it fired rather quickly...the engine idle sputtered still until warmed up 2 mins
Im gonna try new wires..that's about the only thing left from my tune up that is not new... acdelco's on order now.
