Head Lights
Old May 24, 2012 | 02:45 AM
IU-Z07's Avatar
IU-Z07
Default Head Lights
My 94 failed MD inspection so I need to put in some new headlights. ANy suggestions on what bulb to use?
Also, is this a piece of cake swap, or are there any tricks I need to know? Thanks
Old May 24, 2012 | 05:31 AM
weaselbeak's Avatar
weaselbeak
On my '87 I just disconnected the battery and manually cranked the ***** to get it in a good position. I would make sure to disconnect the battery first so they don't take off on you
Old May 24, 2012 | 09:32 PM
VetteMed's Avatar
VetteMed
once you crank the headlights halfway up with the *****, there's one screw on each side of the plastic housing. Then, there's 4 screws that secure the metal retainer bezel to the bucket. Disconnect wiring plug, remove bulb. Installation of new bulb is the reverse of removal
Old May 24, 2012 | 09:42 PM
ghlkal's Avatar
ghlkal
2018 C4 of Year Finalist
Did you fail because of brightness or because of alignment?
Old May 24, 2012 | 11:20 PM
IU-Z07's Avatar
IU-Z07
Thanks for the help. One of the headlights was not bright enough.
Is aiming the new lights hard, or do I just pop them in?
Old May 28, 2012 | 10:42 PM
ghlkal's Avatar
ghlkal
Pop in the bulbs and see where they shine. Adjusting isn't hard, but the adjusting screws are likely rusted so spray them down first.
To Head Lights
