93 Reverse Light Switch
Old May 25, 2012 | 09:52 AM
kittmaster's Avatar
kittmaster
Default 93 Reverse Light Switch
GM has discontinued this switch, and I've proven its the problem, I need to find a proper replacement. Is ZFdoc the way to go? Does anyone have a proper part number and or source for this part?
Any help would be great.
Chris
Old May 25, 2012 | 12:57 PM
blackbear bob's Avatar
blackbear bob
Got mine at Corvette Central. It is a replacement part that does not match the original exactly, but works as intended. Remove the slave cyl for better access.
Old May 25, 2012 | 02:38 PM
kittmaster's Avatar
kittmaster
Did the transmission "leak" anything when you unscrewed it?
Old May 25, 2012 | 04:38 PM
blackbear bob
no leaks when changing
To 93 Reverse Light Switch
