Dash lights....
Old May 23, 2002 | 07:02 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
Default Dash lights....
The orange backround on my dash is pulsing in time with my engine...feels like I'm in a "discovette", especially at night... what's up with this ?... Dan
Old May 23, 2002 | 08:12 AM
tgroghan's Avatar
tgroghan
Default Re: Dash lights.... (golfboy1)
Yeah, my 91 does it too. It's really noticable when you turn your dash lights down. I'm guessing it's normal, just like if you had a large power drawl on a system, the lights go dim. Have you noticed it mostly while the car is sitting still idling or when your out driving at speed? I think I noticed it both times.
Old May 23, 2002 | 09:06 AM
onedef92's Avatar
onedef92
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default Re: Dash lights.... (tgroghan)
My turn signals have also caused this winking phenomenon to occur on my 92's instrument panel. Like other posters, I suspect it's normal.
Old May 23, 2002 | 11:24 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Yes, it is more noticible at idle...as the RPM's increase the pulsing stays in time so it is less noticable but still there...I was hoping some wire just needed shielding....
Old May 23, 2002 | 01:23 PM
jfb's Avatar
jfb
That shouldn't happen. Look at the battery waveform with an oscilloscope. Some voltage regulators in the alternator oscillate at a low frequency causing your dash lights to pulse. Also, you could have a dirty connection in one of the connectors to the dash circuit boards that varies in resistance with engine shake. If your alternator is oscillating, replace the alternator or the voltage regulator.
Old May 24, 2002 | 09:56 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Default Re: Dash lights.... (jfb)
Thanks JFB...I'll check into that..... Dan
Old May 24, 2002 | 09:59 AM
92TripleBlack's Avatar
92TripleBlack
He's right. Check the alternator.
To Dash lights....
