Flexalite Cooler with fan Install help (wiring)
i'm jumping from B&M's 70264 http://www.summitracing.com/parts/BMM-70264/
to the bigger heavy duty Flexalite 45956
http://www.summitracing.com/parts/FLX-45956/
My problem is the wiring :
Here is a picture for the 4595X models
Black + POS wire is already plugged into the single connector.
No problem for the ground (Red wire) (not sure why they
use red as negative and black as positive)
Here is my doubt :
"Run another wire from an ignition switched 15A POS+
power source to either of the two connectors at arrow 2.
An electrical relay and a 15A Slowblow fuse are recommended on the POS side"
What's a good ignition switched source around the front of the car?
i will install the cooler in front of the radiator,where is the B&M now.
I will run an inline small fuse box and wire with the 15A in place.
But the electrical relay ? How can i do that and what's the function of it ???
Thanks !
As a point apart :
I succesfully installed a B&M Trans Temp gauge tapping on the Cigarrete lighter positive wire to later find out that the wire is powered all the time! Will that gauge drain my battery ? I'm planning to swap the wire to the ignition wire (any pictures of this wire?) Thanks !
On my 90 there is a couple of posts next to the battery that feed the car. I'm guessing yours is similar for the most part any Pink wire coming from that area is a "switched" wire easy to test. Turn your ignition on and test a wire. If its hot when the ignition is on and not when its off you have found a good wire. Then use this wire as the trigger for your relay.
Maybe this will help:
Thanks !!!
How the heck do i wire that relay !!!!
Use a DVM to determine which one
Use that wire to power up the the relay ( trigger in the diagram ) that then switches power on a heavier (15A Min ) wire direct from the battery ( fused ) to the fan motor.
Any time you turn the key on ,
the fan will have power available so it will operate whenever the thermo switch in the cooler turns it on
but seems like i have to use the old style (if those are the slow blow ones).-
I got the relay holder too.
Comparing both coolers from side to side, wow there is a major difference!
Bigger with a 900CFM Shrouded fan plus rated at 26,000 GVWR gross vehicle weight ratio.
Hopefully will make a difference, here are the pics compared to the B&M 70264:
I deleted all the AC components so the AC Condenser can get out of there.
The space in front of the aux fan was perfect for the B&M but not for this big boy.
I had to remove the aux fan (i will upgrade to a Dewitts double row radiator & upgraded 2360 cfm fan as soon as i can) so i didn't mind removing the aux fan. Now after removing this i found good space to mount the new cooler.
Now i will need help finding a wire that is "HOT" when the key is on to trigger
the relay. Today i tried my unused AC connector and A.I.R. Pump connectors with no luck.
I just need to mount this cooler tight and go test try it but i need to finish the wiring.
i got the relay, relay holder (with the exposed wires) and fuse holder w/fuse.
Thanks ! ! !
Matthew
i believe it's a puller fan
how can i check if it has different phases? Not sure about it.
The aux fan is hot all the time with the key on?
i will check your thread, thanks !!!
- Why you put the fan looking to the front of the car ?
i believe this act as a puller, it pulls the hot air, so the fan has to go in the same way
the engine fan is, behind the cooler and the hose terminals aiming at the cooling lines.
I would like the fan to work all the time, my aux fan never comes on because
my car never overheats, i will need a new wire, any ideas?
Thanks !
