Troubleshooting fans
Old May 23, 2002 | 10:13 AM
vettes's Avatar
vettes
Default Troubleshooting fans
I have a 200 degree temp. switch wired so both fans go on,installed about 1.5 yrs ago.Recently the fans come on at all different temps,and when they do "service engine light" comes on.code 26,28.How can I diagnose the problem.What could cause this? bad: fan switch,ac pressure switch,relays,ECM???Thanks in advance
Old May 23, 2002 | 02:17 PM
ZylaRace's Avatar
ZylaRace
Default Re: Troubleshooting fans (vettes)
Don't have my manual here. Any idea what 26 or 28 is?
Old May 23, 2002 | 02:19 PM
Camvette's Avatar
Camvette
May be the temp sensor for the ECM. The ECM stills controls the fans even with the other sensor. On my '85 it is located at the front if the intake manifold. Definately the first place I'd look.
[Modified by Camvette, 12:22 PM 5/23/2002]
Old May 23, 2002 | 02:51 PM
vettes's Avatar
vettes
Default Re: Troubleshooting fans (ZylaRace)
26-Check EGR, Canister Purge and AIR pump relays with a digital Ohm meter. A resistance of less than 18 ohms indicates a bad relay. If OK, potential ECM failure.
28-Air conditioning Clutch relay and/or cooling fan relays. Check with digital Ohm meter, replace if less than 18 Ohms. If relays OK, potential ECM failure.
Old May 23, 2002 | 03:07 PM
ZylaRace's Avatar
ZylaRace
I'll presume that is less than 18 across the coil connections.
28 sounds like one of the relay's went bad. The fact of fans coming on at different temp make me think that also. If not check the wiring of the "new" circuit. (Main and aux fan coming on at the same time.)
Old May 23, 2002 | 03:36 PM
vettes's Avatar
vettes
Last nite both fans on.I unplugged one fan relay at a time and that fan went off,when plugged back it it went back on.Does this mean the relays are ok.Should I just pick up a pair of relays and try this first before anything else.
Old May 23, 2002 | 03:50 PM
cire96's Avatar
cire96
Oh. I thought you wanted "fans" of troubleshooting..... :D
Old May 24, 2002 | 10:52 AM
vettes's Avatar
vettes
:confused:
Old May 25, 2002 | 10:48 PM
vettes's Avatar
vettes
TTT
Old May 26, 2002 | 01:22 AM
inkynlisa's Avatar
inkynlisa
1st Gear
my dash speedometer is incorrect(digital) idle is rough,unable to throttle into ive changed
plugs
wires
cap&button
oxgn sensor
had MAP sensor checked
dash doesnt "light"up when lights on(or any other time)YET
cruise doesnt cruise
is these systems of ECM failure? : :confused:
Old May 27, 2002 | 09:53 AM
vettes's Avatar
vettes
Default Re: Troubleshooting fans (inkynlisa)
ttt
Old May 28, 2002 | 12:44 PM
vettes's Avatar
vettes
To Troubleshooting fans
