SBC blocks manifold swaps etc
Old Jun 27, 2014 | 01:26 AM
FrankinChevy's Avatar
FrankinChevy
2nd Gear
the lack of serpentine belts will not be an issue as I have everything set up on a v-belt right now. As far as installing the knock sensor goes is there a tutorial somewhere that I can follow to accomplish this?
Old Jun 29, 2014 | 01:08 PM
powerpigz-51's Avatar
powerpigz-51
If I remember correctly, the hole already exists, with a pipe plug on the pass side of the block roughly in the middle. You can also run without a knock sensor if you run with a resistor to ground. What ECM are you using?
