Ecm/prom ? Help
The car has a chip in the ecm and because of that when they try to read what codes are set with the tech 2 it comes back with no data.
Could this be true? I find it hard to believe that an aftermarket chip would prevent reading codes? The car is an 1989 with a six speed and I have tried to locate a new or used stock chip. The shop says they can't find the problem until they can read the codes.
If I bought a new hypertech chip and installed it would I be able to read the codes.
Can someone chime in with their ideas???
the ignition on. The ECM will turn on the cooling fan and energize
some relays.
The Service Engine Soon indicator lamp will blink any codes.
It will blink 12 three times, any codes three times then 12
again three times which indicates the end. The codes will
continue to cycle again unless you turn the ignition off.
The DTC's for a Mem Cal or Cal Pak error are 51 and 52.
There was a technical service bulletin which I believe included
at least 86-91 Y body vehicles concerning no serial data when using
a Tech 1.
The solution was to use a GM Pin E Adapter.
It was an adapter that plugged on to the end of the Tech 1 cable.
I don't have a Tech 2 but do have a Tech 1. My guess is the Tech
2 also needs this adapter to work on the 89 Corvette.
Here's a link showing the adapter. Scroll way down until you
see GM Pin E adapter. It says it's needed for 86-89 Y body cars.
I think the info is wrong. I have a 90 and need this adapter
when I use the Tech 1.
http://www.boschdiagnostics.com/part...3100parts.aspx
The 89 used Multec fuel injectors (gray body colored injectors). They failed because the injector coil windings were exposed to the fuel.
Eventually the coil winding insulation deteriorated and the coil winding would short out. If this car still has the original injectors use an
ohm meter and measure the resistance of the injector coils.
They should measure around 16 ohms.
Check the resistance hot and cold. Some times you can isolate
the problem by disconnecting the injector connector. Remove one
and see if the engine runs better. If no change move on to the
next injector.
some relays.
a Tech 1.
next injector.
