Gas pedal
Old May 23, 2002 | 05:02 PM
DADDY D's Avatar
DADDY D
Default Gas pedal
my gas pedal sticks sometimes when you first press on it it is hard then it goes is there a way to fix this
Old May 23, 2002 | 05:17 PM
rocketfinger's Avatar
rocketfinger
Default Re: Gas pedal (DADDY D)
Mine was notchy when I bought the car, sat on dealer lots too long I think. It's since loosened up and is really good. Might wanna check the throttle cable for kinks/wear/gummed-up etc.
Old May 23, 2002 | 10:36 PM
DADDY D's Avatar
DADDY D
Default Re: Gas pedal (rocketfinger)
i will check that out..
Old May 24, 2002 | 05:24 PM
DADDY D's Avatar
DADDY D
any other ideas
Old May 24, 2002 | 06:49 PM
Vetterin's Avatar
Vetterin
Check the butterfly on your TB. Sometimes if it is dirty it will stick in the closed position and you will feel it in the gas pedal. A good cleaning just might do the trick.
To Gas pedal
