Replacement Starter From Summit
Old Jun 1, 2012 | 07:14 PM
gdblssvettes's Avatar
gdblssvettes
Default Replacement Starter From Summit
Looking at this starter http://www.summitracing.com/parts/SUM-829100/ for my '89. What do you think about that. My OEM is toast. Brushes are toast and contacts in solenoid are worn.
Old Jun 2, 2012 | 11:51 PM
mako41's Avatar
mako41
You probably could rebuild your OEM starter, it's the plunger and copper contacts that need to be replaced. Check out these threads;
http://www.corvetteactioncenter.com/...o-starter.html
http://forums.corvetteforum.com/c4-t...with-pics.html
Or if you want to replace it with an OEM GM remanufactured part, best price you'll find;
http://www.autopartstomorrow.com/par...-reman-starter
