I have had a Dynaspark stored for the last 4 years in case my opti spark went out, it is starting to fail after checking system. I can't find the instructions as I am not sure where to hook up the inlet lead for the air tube on the top. The bottom one hooks up to the vaccum line with a "T". This is on a '93. I wonder what the newer opti's hooked to on a 95 and 96 with the vaccum lines or pictures of it or a part to use from the newer ones to install on mine.
Thanks, that was what I needed so I could properly do the job. I did see another post on another forum about running the inlet air line inside under the dash so as not to draw as much moisture into the unit, sounds like that would be a good idea.
Hopefully the dynaspark you have stored is one of the 'old' designs and not the new 'bastardized' dynaspark after the company was sold.
