Powder Coat may not be the best finish choice
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Recently purchased and installed a new flexplate from Scat that was Black powder coated. I ordered a "cad" plate.
Bolt torque specs were applied and double checked.
During a starter inspection today, all three torque converter bolts were discovered loose and could be removed without tools.
The paint was flaking off underneath bolt heads and TC flanges, thereby reducing the torque value to zero.
The decision to check the 6 crankshaft bolts was wise as the same condition was found there as well.
The shocking part of this discovery is only 100 miles had been accumulated on the installation! No heavy driving or horsing around.
I will contacting Scat. But in the mean time be advised that powder coat will not hold up to the pressure underneath bolt/nuts.
Received 3,043 Likes
St. Jude Donor '05
Oh boy...good save, major bullet dodged there! Whod have guessed?
Maybe I am missing something here, but why powder coat a flex plate? It cant be seen, and I have never seen or heard of a flexplate rusting especially to the point it caused structural damage.
I dont think there Powdercoat had the proper curing time or temperature, at the shop I work at we can hit a 1/4 plate on the edge with a sledge hammer and the PC will not fail. It is a science and if there setting arent just right you will have PC failure. I have seen it a thousand times but thats just my opinion
Locktight would not have made any difference.
The paint crushed under the pressure after torque was applied.
It took a short while before every bolt on the flex plate was loose.
We ground off the paint around the bolt holes (both sides) and applied blue loctite before torquing.
St. Jude Donor '05
To keep it from rusting on the boatride over
Ya know I questioned the PC as well.
But coming from a company like SCAT who would question their integrity?
Shouldn't be a problem. Just clean the paint from where the heads will contact the cover.
While it is true that you can smack pc with hammer and not hurt it, tightening down a bolt is whole different story. The twisting and the pressure combined will remove the pc BUT you will not be able to see the bare spot because it will come off right at the fasteners edge. Before I started doing my own pc I was having it done by House of Powder, it was one of the first pc businesses around and you can probably Google them to read about them. Anyway, the first time I did business with them they expressed the fact of the pc failing under a bolt or nut, they did not want a dissatisfied customer. Once I started doing my own I experimented with different methods but they all ended up the same way.
