93 6-speed clutch replacement?
The slave cylinder has been replaced already (by Cauley Chevrolet) and was leaking/losing clutch fluid for some time (it was continually topped off until the slave was finally replaced last year). The clutch feels to slip under 1/3 or more acceleration. Cauley also said that the clutch is in need of replacement.
The car has always run strong for a bone-stock 93. What clutch is recommended? Should the flywheel be replaced as well or just resurfaced? Also, are there any recommended shops/dealers in SE Michigan to perform the service?
Any/all info is greatly appreciated, and thank you in advance!
But then again...I'm frugal (cheap)
Any, call Tom at Carolina clutch, and he can give you the best advice. Pulling trannies is not something you want to do too often.
