Steering column q?
Old Jun 7, 2012 | 08:56 PM
85orangec4's Avatar
85orangec4
Default Steering column q?
So i had to disassemble the column on my 85, and i have come to the realization that my lockplate clip is nonexistant. someone was in the column before me, as the tilt spring retainer was already a little mangled (the one you have to press in really hard and twist). does anyone by chance have a p/n, picture or anything about this lockplate retaining clip. i may be able to make one or find something in the bins at advance auto, etc, but i have no idea what it ever looked like! if anyone could help that would be awesome.
Old Jun 7, 2012 | 08:58 PM
ch@0s's Avatar
ch@0s
Does this help?
http://forums.corvetteforum.com/c4-t...s-of-pics.html
Old Jun 7, 2012 | 09:00 PM
85orangec4's Avatar
85orangec4
also just had a thought, this clip should be the same for many makes and models correct? if so, the dealer should be able to order one...
Old Jun 7, 2012 | 09:03 PM
85orangec4's Avatar
85orangec4
thanks i saw that one, i just cant see what the clip looks like.
Old Jun 8, 2012 | 11:35 AM
85orangec4's Avatar
85orangec4
if someone could tell me how to put up a .pdf on here, i think i have the clearest ever picture of the exploded steering column. it is truly priceless
Old Jun 8, 2012 | 03:11 PM
ch@0s's Avatar
ch@0s
If you found it on line right click on it then copy location. Once you have that on your clipboard click on the earth with the paper clip and paste the info there. If you did not find it on line you can save it as an image and share it pretty easily.
To Steering column q?
