Gas pedal pressure
Old Jun 8, 2012 | 07:55 AM
Old Ben's Avatar
Old Ben
2017 C6 of Year Finalist
Default Gas pedal pressure
I got in my 92 Vette this morning to drive it to work. It started as normal and idled fine. When I applied pressure to the gas pedal I had to push harder than normal and the car did a jack rabbit start. I could not accelerate slowly from a stop. Once rolling the gas pedal seemed to work normally.
I have checked the cable and could not find any binding. It feels almost like a pedal push back. Any help would be appreciated.
Old Jun 8, 2012 | 08:08 AM
Moon86's Avatar
Moon86
The same thing was happening to my 85. The only thing that helped me was putting an extra universal carb spring on. It was only supposed to be a temp fix but 2 yrs later it's still there.
Moon
Old Jun 8, 2012 | 08:43 AM
caddyboy84's Avatar
caddyboy84
I just posted the same question. My car needed to jump a little each time I pulled away from a stop, I think the throttle-body is sticking a little. I tried to oil the butterfly shaft but it didnt really help. The majority believe it's time for a throttle-body.
Old Jun 8, 2012 | 09:18 AM
dsandmire's Avatar
dsandmire
My 87 has the same problem--though not sure why yours just started sticking today. IF the butterfly valve shaft get worn, the butterfly can travel sideways and stick/hang-up on the inside of the TB. Mine was ok and the trottle cable is permanently lubed teflon [i think] so maybe something simple like the pedal is sticking or the floor mat is up against it--sometimes it is the simple things....
Old Jun 8, 2012 | 07:07 PM
93Rubie's Avatar
93Rubie
Could be throttle body related, either plates sticking on carbon or shaft is binding. Also, possible on a 92 for the ASR motor/cable assembly to have a issue as well. Remove the Black ASR Box cover to inspect the cable spool, IDK what you want to call it? Check pedal assy. itself, and obviously the cables.
I've found it not uncommon for higher mileage cars with actual throttle cables to have the carbon make the plates stick a bit if the car is not at or near WOT very often. Never a problem on my Corvette.
Old Jun 8, 2012 | 07:09 PM
leesvet's Avatar
leesvet
The liner or sleeve thats inside the cable runs the length of the cable and can and does break and bind somewhere inside the cable sheath. It can be near the end where chunks fall out and tattle tale, or it might be way up inside where you will never see it. Wire strands also break and cause binding. If thats the case the cable must be replaced asap. The result of a stuck throttle on a C4 is not good...
I had it happen and drove a different car under a p/u before I could kill it and shift out of gear...That left a noticable mark on the hood paint...
D/C the cable from the throttle body and operate the cable back/forth to see if this is happening. If not, hose out the throttle body with spray cleaner. Its better to be dry that wet with oil that collects dust and dirt in the shaft bushing.
Old Jun 8, 2012 | 08:07 PM
caddyboy84's Avatar
caddyboy84
After this thread, I went out and inspected my TB a little more. Turns out that I have a little latteral play in the shaft I'm pissed, GOD it's always something I know from experience, that shaft should not move, oh well.........Here I go again
Old Jun 8, 2012 | 08:39 PM
Old Ben's Avatar
Old Ben
Thanks for all the replies. My problem is fixed. Stupid simple.
When I checked the cables this morning I was concentrating on the one from the pedal to the ASR and only gave a quick look at the one from the ASR to the throttle body. While going over it this afternoon I discovered that the end of the cable at the throttle body had jumped out of the channel on the arm. After I put it back in everything is fine.
Old Jun 8, 2012 | 08:44 PM
WW7's Avatar
WW7
Glad you had a quick fix, but you had a ton of other answers if you needed them, these guys covered just about anything it could have been......WW
Old Jun 8, 2012 | 09:13 PM
Old Ben's Avatar
Old Ben
I have received some very good advice on other threads that I posted also. I pulled out the FSM and read these replies atleast twice before I went to start checking it. I hate overlooking the simple things.
To Gas pedal pressure
